[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0beta1-1-ga4c1ccb
git at osgeo.org
git at osgeo.org
Thu Dec 10 03:34:06 PST 2020
the project "PostGIS".
via a4c1ccbb1f983adf3cdd5e8e8c848d711bd120d6 (commit)
from 721a0b732c6c96a23e9703d195aadae95760098c (commit)
revisions in full, below.
commit a4c1ccbb1f983adf3cdd5e8e8c848d711bd120d6
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Dec 10 12:26:51 2020 +0100
Fix GEOS conversion of POINT EMPTY to retain type
References #4815 in master branch
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index e1e8e6a..10b17e1 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -426,7 +426,7 @@ LWGEOM2GEOS(const LWGEOM* lwgeom, uint8_t autofix)
lwp = (LWPOINT*)lwgeom;
if (lwgeom_is_empty(lwgeom))
- g = GEOSGeom_createEmptyPolygon();
+ g = GEOSGeom_createEmptyPoint();
else
#if POSTGIS_GEOS_VERSION < 38
diff --git a/regress/core/geos_noop.sql b/regress/core/geos_noop.sql
new file mode 100644
index 0000000..f38d9f3
--- /dev/null
+++ b/regress/core/geos_noop.sql
@@ -0,0 +1,12 @@
+SELECT
+ --ST_AsEWKT(g),
+ ST_AsEWKT(postgis_geos_noop(g)) FROM ( VALUES
+('SRID=4326;POINT EMPTY'),
+('SRID=4326;MULTIPOINT EMPTY'),
+('SRID=4326;LINESTRING EMPTY'),
+('SRID=4326;MULTILINESTRING EMPTY'),
+('SRID=4326;POLYGON EMPTY'),
+('SRID=4326;MULTIPOLYGON EMPTY'),
+('SRID=4326;GEOMETRYCOLLECTION EMPTY')
+--,('SRID=4326;GEOMETRYCOLLECTION(POINT EMPTY, LINESTRING EMPTY, POLYGON EMPTY, GEOMETRYCOLLECTION EMPTY)')
+) as foo(g);
diff --git a/regress/core/geos_noop_expected b/regress/core/geos_noop_expected
index 0000000..843d29f
--- /dev/null
+++ b/regress/core/geos_noop_expected
@@ -0,0 +1,7 @@
+SRID=4326;POINT EMPTY
+SRID=4326;MULTIPOINT EMPTY
+SRID=4326;LINESTRING EMPTY
+SRID=4326;MULTILINESTRING EMPTY
+SRID=4326;POLYGON EMPTY
+SRID=4326;MULTIPOLYGON EMPTY
+SRID=4326;GEOMETRYCOLLECTION EMPTY
Summary of changes:
liblwgeom/lwgeom_geos.c | 2 +-
regress/core/geos_noop.sql | 12 ++++++++++++
regress/core/geos_noop_expected | 7 +++++++
3 files changed, 20 insertions(+), 1 deletion(-)
create mode 100644 regress/core/geos_noop.sql
create mode 100644 regress/core/geos_noop_expected
hooks/post-receive
