[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0beta1-8-gdf2e83f
Thu Dec 10 15:56:01 PST 2020
the project "PostGIS".
       via  df2e83f12d583a682673a1f743b96181737b22d6 (commit)
      from  a24fb6397bb3b2e2e0674475d1e51d0f0826c350 (commit)
revisions in full, below.
commit df2e83f12d583a682673a1f743b96181737b22d6
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Dec 10 15:55:53 2020 -0800
    Fix doc distance function descriptions
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index 2c81460..4cecb5b 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -2073,7 +2073,7 @@ ST_DWithin(
 				<parameter>distance_meters</parameter></paramdef>
 				<paramdef choice="opt"><type>boolean </type>
-				<parameter>use_spheroid</parameter></paramdef>
+				<parameter>use_spheroid = true</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -2085,28 +2085,28 @@ ST_DWithin(
 		<para>For <type>geometry</type>: The distance is specified in units defined by the
 		spatial reference system of the geometries.  For this function to make
-		sense, the source geometries must both be of the same coordinate projection,
-		having the same SRID.</para>
+		sense, the source geometries must be in the same coordinate system
+		(have the same SRID).</para>
-		<para>For <type>geography</type> units are in meters and measurement is
-		defaulted to <varname>use_spheroid</varname>=true, for faster check, <varname>use_spheroid</varname>=false to measure along sphere.
+		<para>For <type>geography</type>: units are in meters and distance measurement
+		defaults to <varname>use_spheroid</varname>=true.
+        For faster evaluation use <varname>use_spheroid</varname>=false to measure on the sphere.
 		</para>
+		<note><para>Use <xref linkend="ST_3DDWithin"/> for 3D geometries.</para></note>
 		<note>
-		  <para>This function call will automatically include a bounding box
-		  comparison that will make use of any indexes that are available on
+		  <para>This function call includes a bounding box
+		  comparison that makes use of any indexes that are available on
 		  the geometries.</para>
 		</note>
 		<note>
 		  <para>Prior to 1.3, ST_Expand was commonly used in conjunction with && and ST_Distance to
-		  achieve the same effect and in pre-1.3.4 this function was basically short-hand for that construct.
-		  From 1.3.4, ST_DWithin uses a more short-circuit distance function which should make it more efficient
-		  than prior versions for larger buffer regions.</para>
+		  test for distance, and in pre-1.3.4 this function used that logic.
+		  From 1.3.4, ST_DWithin uses a faster short-circuit distance function.</para>
 		</note>
-		<note><para>Use ST_3DDWithin if you have 3D geometries.</para></note>
 		<para>&sfs_compliant;</para>
 		<para>Availability: 1.5.0 support for geography was introduced</para>
 		<para>Enhanced: 2.1.0 improved speed for geography. See <ulink url="http://blog.opengeo.org/2012/07/12/making-geography-faster/">Making Geography faster</ulink> for details.</para>
@@ -2186,10 +2186,10 @@ SELECT b.tower_id, b.geom
 			circle with center <varname>center_x</varname>,<varname>center_y</varname>
             and radius <varname>radius</varname>.
         </para>
-		<warning><para>Does use spatial indexes. Use <xref linkend="ST_DWithin" /> instead.</para></warning>
+		<warning><para>Does not use spatial indexes. Use <xref linkend="ST_DWithin" /> instead.</para></warning>
 		<para>Availability: 1.2</para>
-		<para>Changed: 2.2.0 In prior versions this used to be called ST_Point_Inside_Circle</para>
+		<para>Changed: 2.2.0 In prior versions this was called ST_Point_Inside_Circle</para>
 	  </refsection>
Summary of changes:
 doc/reference_relationship.xml | 28 ++++++++++++++--------------
 1 file changed, 14 insertions(+), 14 deletions(-)
hooks/post-receive
