[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-23-gd052427
git at osgeo.org
git at osgeo.org
Mon Dec 21 17:41:24 PST 2020
the project "PostGIS".
via d052427a764598f6afe960078a8a61fc7b419479 (commit)
from a26921025c6d8d1d2385e4dca69bb55d81d85bc9 (commit)
revisions in full, below.
commit d052427a764598f6afe960078a8a61fc7b419479
Author: Regina Obe <lr at pcorp.us>
Date: Mon Dec 21 20:41:19 2020 -0500
Put back in voronoi tests and flip table name suffix to 32
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index 00eac6a..c896340 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -8,9 +8,9 @@
using a garden variety of geometries. Its intent is to flag major crashes.
<xsl:output method="text" />
- <xsl:variable name='testversion'>3.1.0</xsl:variable>
+ <xsl:variable name='testversion'>3.2.0</xsl:variable>
<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
- <xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable ST_VoronoiLines ST_VoronoiPolygons</xsl:variable>
+ <xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
<!--This is just a place holder to state functions not supported or tested separately -->
<xsl:variable name='var_srid'>3395</xsl:variable>
@@ -33,7 +33,7 @@
<xsl:variable name='var_matrix'>'FF1FF0102'</xsl:variable>
<xsl:variable name='var_boolean'>false</xsl:variable>
<xsl:variable name='var_geom_name'>the_geom</xsl:variable>
- <xsl:variable name='var_logtable'>postgis_garden_log31</xsl:variable>
+ <xsl:variable name='var_logtable'>postgis_garden_log32</xsl:variable>
<xsl:variable name='var_logupdatesql'>UPDATE <xsl:value-of select="$var_logtable" /> SET log_end = clock_timestamp()
FROM (SELECT logid FROM <xsl:value-of select="$var_logtable" /> ORDER BY logid DESC limit 1) As foo
WHERE <xsl:value-of select="$var_logtable" />.logid = foo.logid AND <xsl:value-of select="$var_logtable" />.log_end IS NULL;</xsl:variable>
diff --git a/doc/xsl/raster_gardentest.sql.xsl b/doc/xsl/raster_gardentest.sql.xsl
index 80b255a..13af0e5 100644
--- a/doc/xsl/raster_gardentest.sql.xsl
+++ b/doc/xsl/raster_gardentest.sql.xsl
@@ -8,7 +8,7 @@
using a garden variety of rasters. Its intent is to flag major crashes.
<xsl:variable name='fnexclude'>AddRasterColumn AddRasterConstraints DropRasterConstraints DropRasterColumn DropRasterTable</xsl:variable>
<!--This is just a place holder to state functions not supported in 1.3 or tested separately -->
@@ -31,7 +31,7 @@
<xsl:variable name='var_rastercolumn'>'rast'</xsl:variable>
<xsl:variable name='var_rastertable'>'pgis_rgarden_1bb'</xsl:variable>
- <xsl:variable name='var_logtable'>raster_garden_log31</xsl:variable>
+ <xsl:variable name='var_logtable'>raster_garden_log32</xsl:variable>
<xsl:variable name='var_pixeltypes'>{8BUI,1BB}</xsl:variable>
<xsl:variable name='var_pixelvalues'>{255,0}</xsl:variable>
<xsl:variable name='var_algorithm'>'Lanczos'</xsl:variable>
Summary of changes:
doc/xsl/postgis_gardentest.sql.xsl | 6 +++---
doc/xsl/raster_gardentest.sql.xsl | 4 ++--
2 files changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
