[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-26-g27cd95c
git at osgeo.org
git at osgeo.org
Thu Dec 31 14:50:27 PST 2020
the project "PostGIS".
via 27cd95caf3cf16ab27dcb908c5b786c6ab36bafd (commit)
via 0a5e4864ccdd348b9e9bb1dab25afa41c990ed59 (commit)
from c063dad34d41907d9e65394f340971e53e01df4e (commit)
revisions in full, below.
commit 27cd95caf3cf16ab27dcb908c5b786c6ab36bafd
Merge: 0a5e486 c063dad
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Dec 31 14:50:24 2020 -0800
Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis
commit 0a5e4864ccdd348b9e9bb1dab25afa41c990ed59
Date: Thu Dec 31 14:49:24 2020 -0800
Make the VSICURL synthetic driver work as documented. Closes #4818
diff --git a/raster/rt_core/rt_util.c b/raster/rt_core/rt_util.c
index 18a68b5..f616a56 100644
--- a/raster/rt_core/rt_util.c
+++ b/raster/rt_core/rt_util.c
@@ -392,10 +392,11 @@ rt_util_gdal_open(const char *fn, GDALAccess fn_access, int shared) {
/* do nothing */
else if (
- (strstr(fn, "/vsicurl") != NULL) &&
+ (strstr(fn, "/vsi") != NULL) &&
+ (strstr(fn, "/vsimem") == NULL) &&
(strstr(gdal_enabled_drivers, GDAL_VSICURL) == NULL)
- rterror("rt_util_gdal_open: Cannot open VSICURL file. VSICURL disabled");
+ rterror("rt_util_gdal_open: Cannot open %s file. %s disabled", GDAL_VSICURL, GDAL_VSICURL);
return NULL;
diff --git a/raster/rt_pg/rtpostgis.c b/raster/rt_pg/rtpostgis.c
index be97205..278115c 100644
--- a/raster/rt_pg/rtpostgis.c
+++ b/raster/rt_pg/rtpostgis.c
@@ -278,6 +278,7 @@ static void
rtpg_assignHookGDALEnabledDrivers(const char *enabled_drivers, void *extra) {
int enable_all = 0;
int disable_all = 0;
+ int vsicurl = 0;
char **enabled_drivers_array = NULL;
uint32_t enabled_drivers_count = 0;
@@ -294,6 +295,8 @@ rtpg_assignHookGDALEnabledDrivers(const char *enabled_drivers, void *extra) {
if (enabled_drivers == NULL)
return;
+ elog(DEBUG4, "Enabling GDAL drivers: %s", enabled_drivers);
/* destroy the driver manager */
/* this is the only way to ensure GDAL_SKIP is recognized */
GDALDestroyDriverManager();
@@ -325,6 +328,14 @@ rtpg_assignHookGDALEnabledDrivers(const char *enabled_drivers, void *extra) {
+ else if (strstr(enabled_drivers, GDAL_VSICURL) != NULL) {
+ for (i = 0; i < enabled_drivers_count; i++) {
+ if (strstr(enabled_drivers_array[i], GDAL_VSICURL) != NULL) {
+ enabled_drivers_found[i] = TRUE;
+ vsicurl = 1;
if (!enable_all) {
int found = 0;
@@ -393,6 +404,9 @@ rtpg_assignHookGDALEnabledDrivers(const char *enabled_drivers, void *extra) {
elog(WARNING, "Unknown GDAL driver: %s", enabled_drivers_array[i]);
+ if (vsicurl)
+ elog(WARNING, "%s set.", GDAL_VSICURL);
diff --git a/raster/test/cunit/cu_misc.c b/raster/test/cunit/cu_misc.c
index 3427605..24c618d 100644
--- a/raster/test/cunit/cu_misc.c
+++ b/raster/test/cunit/cu_misc.c
@@ -134,12 +134,12 @@ static void test_util_gdal_open() {
CU_ASSERT(ds == NULL);
/* enabled drivers with VSICURL */
- /* disabled as we don't want network access as a requirement
- gdal_enabled_drivers = enabled_vsi;
- ds = rt_util_gdal_open("/vsicurl/http://download.osgeo.org/gdal/data/gtiff/small_world.tif", GA_ReadOnly, 0);
- CU_ASSERT(ds != NULL);
- GDALClose(ds);
+ /* disabled as we don't want network access as a requirement */
+ // gdal_enabled_drivers = enabled_vsi;
+ // ds = rt_util_gdal_open("/vsicurl/http://download.osgeo.org/gdal/data/gtiff/small_world.tif", GA_ReadOnly, 0);
+ // CU_ASSERT(ds != NULL);
+ // GDALClose(ds);
/* register tests */
Summary of changes:
raster/rt_core/rt_util.c | 5 +++--
raster/rt_pg/rtpostgis.c | 14 ++++++++++++++
raster/test/cunit/cu_misc.c | 12 ++++++------
3 files changed, 23 insertions(+), 8 deletions(-)
hooks/post-receive
