[postgis-tickets] [PostGIS] #4635: ST_3DDwithin speed slow down between 2.5 and 3.0
PostGIS trac at osgeo.org
Tue Feb 4 09:11:11 PST 2020
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 3.0.1
 Component:  postgis  |    Version:  3.0.x
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> I haven't checked this out but as reported on postgis-users mailing list
> I suspect the culprit is postgis 3.0 and not the 11 -> 12 move because
> changing the signatures to not use the function instrumentation did not
> help.
> So I'm suspecting its the changes in the 3D functions we did to support
> additional types.
> https://lists.osgeo.org/pipermail/postgis-users/2020-February/043850.html
> Sample data set to exercise:
> https://github.com/tomka/tmp/blob/master/postgres/catmaid-postgis-
> test.pgsql
>  Changed intersection test speed after PG 11 -> 12 and PostGIS 2.5 -> 3
> upgrade
> For completeness, news repeated
> I took a bit of published data (in my case neuron morphologies from [0])
> and created an isolated database that only contained the minimal
> versions of the tables referenced in this query. Both tables have 328738
> rows and I crated all the indices that are there in the original tables.
> With this, I believe, the effect is visible. The 12MB SQL dump (in
> Postgres custom format) can be found here:
> test.pgsql
> If I run the query from my initial email in both Postgres 11 / PostGIS
> 2.5 and Postgres 12 / PostGIS 3, I get the following query plans on the
> machine that also ran the databases of the original query. First,
> Postgres 11/ PostGIS 2.5:
>   Limit  (cost=51.71..498.33 rows=102 width=16) (actual time=2.023..2.697
>   rows=215 loops=1)
>     Buffers: shared hit=1159
>     CTE bb_edge
>       ->  Bitmap Heap Scan on treenode_edge te  (cost=2.43..44.77 rows=1
> width=16) (actual time=1.348..1.804 rows=143 loops=1)
>             Recheck Cond: (edge &&&
> '01020000800200000000000000F0C71C41000000007026144100000000C095034100000000F88D20410000000070B511410000000080940341'::geometry)
>             Filter: ((edge &&
> '0103000080010000000500000000000000A0C71C410000000020B51141000000008094034100000000A0C71C4100000000C0261441000000008094034100000000208E204100000000C026144100000000C095034100000000208E20410000000020B5114100000000C095034100000000A0C71C410000000020B511410000000080940341'::geometry)
> AND (project_id = 1) AND
> ('0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry
> && st_expand(edge, '20'::double precision)) AND _st_3ddwithin(edge,
> '0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry,
>             Heap Blocks: exact=119
>             Buffers: shared hit=167
>             ->  Bitmap Index Scan on treenode_edge_gix  (cost=0.00..2.43
> rows=19 width=0) (actual time=1.321..1.321 rows=143 loops=1)
>                   Index Cond: (edge &&&
>                   Buffers: shared hit=48
>     ->  Nested Loop  (cost=6.93..453.55 rows=102 width=16) (actual
> time=2.022..2.674 rows=215 loops=1)
>           ->  HashAggregate  (cost=6.51..9.57 rows=102 width=8) (actual
> time=2.004..2.045 rows=259 loops=1)
>                 Group Key: bb_edge.id
>                 ->  Append  (cost=0.00..6.26 rows=102 width=8) (actual
> time=1.351..1.917 rows=338 loops=1)
>                       ->  CTE Scan on bb_edge  (cost=0.00..0.06 rows=1
> width=8) (actual time=1.351..1.863 rows=143 loops=1)
>                       ->  CTE Scan on bb_edge bb_edge_1  (cost=0.00..0.06
> rows=1 width=8) (actual time=0.000..0.017 rows=143 loops=1)
>                       ->  ProjectSet  (cost=0.00..1.55 rows=100 width=8)
> (actual time=0.003..0.008 rows=52 loops=1)
>                             ->  Result  (cost=0.00..0.03 rows=1 width=0)
> (actual time=0.000..0.000 rows=1 loops=1)
>           ->  Index Scan using treenode_pkey on treenode t1
> (cost=0.42..4.32 rows=1 width=16) (actual time=0.002..0.002 rows=1
> loops=259)
>                 Index Cond: (id = bb_edge.id)
>                 Buffers: shared hit=992
>   Planning Time: 0.755 ms
>   Execution Time: 2.765 ms
> And this is Postgres 12 / PostGIS 3:
>   Limit  (cost=32.51..220.67 rows=54 width=16) (actual time=2.934..3.876
> rows=215 loops=1)
>     Buffers: shared hit=1190
>     CTE bb_edge
>       ->  Index Scan using treenode_edge_gix on treenode_edge te
> (cost=0.53..28.58 rows=1 width=16) (actual time=0.276..2.641 rows=143
> loops=1)
>             Index Cond: ((edge &&&
> AND (edge &&&
> st_expand('0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry,
> '20'::double precision)))
>             Filter: ((project_id = 1) AND st_3ddwithin(edge,
>             Buffers: shared hit=198
>     ->  Nested Loop  (cost=3.94..192.09 rows=54 width=16) (actual
> time=2.931..3.847 rows=215 loops=1)
>           ->  HashAggregate  (cost=3.51..5.13 rows=54 width=8) (actual
> time=2.893..2.948 rows=259 loops=1)
>                 ->  Append  (cost=0.00..3.38 rows=54 width=8) (actual
> time=0.285..2.768 rows=338 loops=1)
> width=8) (actual time=0.284..2.704 rows=143 loops=1)
> rows=1 width=8) (actual time=0.001..0.020 rows=143 loops=1)
>                       ->  ProjectSet  (cost=0.00..0.83 rows=52 width=8)
> (actual time=0.006..0.013 rows=52 loops=1)
> (actual time=0.001..0.001 rows=1 loops=1)
> (cost=0.42..3.43 rows=1 width=16) (actual time=0.003..0.003 rows=1
> loops=259)
>   Planning Time: 1.148 ms
>   Execution Time: 3.981 ms
> And just for easier context, this is the query I used (from the first
> mail):
>    EXPLAIN (ANALYZE, BUFFERS) WITH bb_edge AS (
>    SELECT te.id, te.parent_id
>     FROM treenode_edge te
>     WHERE te.edge &&& ST_MakeLine(ARRAY[
>         ST_MakePoint(471548.0, 330140.0, 160440.0),
>         ST_MakePoint(542460.0, 290140.0, 160400.0)] ::geometry[])
>     AND ST_3DDWithin(te.edge, ST_MakePolygon(ST_MakeLine(ARRAY[
>         ST_MakePoint(471548.0,  290140.0,    160420.0),
>         ST_MakePoint(542460.0, 290140.0,    160420.0),
>         ST_MakePoint(542460.0, 330140.0, 160420.0),
>         ST_MakePoint(471548.0,  330140.0, 160420.0),
>         ST_MakePoint(471548.0,  290140.0,    160420.0)]::geometry[])),
>         20.0)
>     AND te.project_id = 1
>    SELECT
>      t1.id,
>      t1.parent_id
>    FROM (
>      SELECT id FROM bb_edge
>      UNION
>      SELECT parent_id FROM bb_edge
>      UNION
>      SELECT UNNEST(ARRAY[41851780,25932042,25932043,14274317,25932045,
>        25932050,25932052,41876633,25932070,42769832,25932073,25932076,
>        42769838,25932082,25932084,27641652,25220534,25932087,41421110,
>        26002235,36359611,25932094,36359614,41421118,41420481,41876677,
>        25932101,27641926,27641927,27642056,25932233,41420487,25932235,
>        25932108,27642059,40327244,25932111,25932243,25967062,25967066,
>        25967067,25967069,25967070,25932130,27642082,25932132,27642085,
>        25967080,25967082,25967084,27642099,28873207]::bigint[])
>    LIMIT 80000;
> Let me know if I can be of more help.
> Thanks,
> Tom
> [0] https://www.cell.com/cell/pdf/S0092-8674(18)30787-6.pdf
> On Mon, Feb 03, 2020 at 02:46:59AM -0500, Regina Obe wrote:
> >It could be the change in logic of _ST_3DDWithin. That was changed to
> support more 3d types, so that might have caused a slow down elsewhere.
> >If you can provide a dataset that would be great.  I'll try to do some
> benchmarks on some 3d sets I have lying around.
> >Thanks,
> >Regina
New description:
 help.
 additional types.
 test.pgsql
 upgrade
 test.pgsql
   rows=215 loops=1)
     CTE bb_edge
             Filter: ((edge &&
 loops=259)
 rows=215 loops=1)
     CTE bb_edge
 loops=1)
 AND (edge &&&
 loops=259)
 mail):
         20.0)
    SELECT
      t1.id,
      t1.parent_id
    FROM (
      UNION
      UNION
    LIMIT 80000;
 Thanks,
 Tom
 >Thanks,
 >Regina
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4635#comment:1>
