[postgis-tickets] [PostGIS] #4636: ST_Subdivide degrade data
PostGIS trac at osgeo.org
Fri Feb 7 05:04:34 PST 2020
  Reporter:  sirsosp  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.5.4
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:
Comment (by sirsosp):
 here is the SQL Query to reproduce the issue :
 DROP TABLE IF EXISTS data_olivier.test_for_stsubdivide_processed;
 CREATE TABLE data_olivier.test_for_stsubdivide_processed AS
 SELECT
   ST_Multi(ST_Subdivide(geom,500))::geometry(MultiPolygon , 2154) AS geom,
   cod19niv4,
   cod19niv5
 FROM data_olivier.test2_for_stsubdivide
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4636#comment:1>
