[postgis-tickets] [PostGIS] #4636: ST_Subdivide degrade data
PostGIS trac at osgeo.org
Fri Feb 7 07:24:24 PST 2020
  Reporter:  sirsosp  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.5.4
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:
Comment (by strk):
 Kind of snaptogrid is what you get when floating precision
 operation can't complete due to some robustness issue
 (lines almost parallel that intersect, usually).
 Even if the problem occurs on a very small portion of the
 geometry, precision reduction is applied to the whole geometry,
 incrementally, until the operation succeeds.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4636#comment:4>
