[postgis-tickets] [PostGIS] #4638: bessie failing on GDAL segmentation fault
PostGIS trac at osgeo.org
Sat Feb 8 13:10:16 PST 2020
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  assigned
  Priority:  medium                 |  Milestone:  PostGIS 3.0.1
 Component:  build/upgrade/install  |    Version:  3.0.x
Resolution:                         |   Keywords:
Comment (by robe):
 confirmed deleting those files fixes the issue
 https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie/1902/console
 16:04:43 Loading PostGIS into 'postgis_reg'
 16:04:43
 /usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/0c190406e5edf3050c2883cc378e628fbdf26d3e/regress/00
 -regress-install/share/contrib/postgis/postgis.sql
 16:04:43
 -regress-install/share/contrib/postgis/postgis_comments.sql
 16:04:44
 -regress-install/share/contrib/postgis/postgis_proc_set_search_path.sql
 16:04:44
 -regress-install/share/contrib/postgis/spatial_ref_sys.sql
 16:04:47 PostgreSQL 11.4 on amd64-portbld-freebsd12.0, compiled by FreeBSD
 clang version 6.0.1 (tags/RELEASE_601/final 335540) (based on LLVM 6.0.1),
 64-bit
 16:04:47   Postgis 3.0.1dev - r0c19040 - 2020-02-08 16:27:33
 16:04:47   scripts 3.0.1dev 0c19040
 16:04:47   GEOS: 3.7.2-CAPI-1.11.2 b55d2125
 16:04:47   PROJ: 6.1.1
 16:04:47
 16:04:47 Running tests
 16:04:47
 16:04:47  ../loader/Point .............. ok
 Going to keep this ticket open as I suspect it will happen again
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4638#comment:4>
