[postgis-tickets] [PostGIS] #4597: [doc] ST_SetSRID should explain difference with ST_Transform
PostGIS trac at osgeo.org
Tue Feb 11 14:40:35 PST 2020
  Reporter:  komzpa         |      Owner:  komzpa
      Type:  defect         |     Status:  closed
  Priority:  medium         |  Milestone:  PostGIS 3.0.1
 Component:  documentation  |    Version:  master
Resolution:  fixed          |   Keywords:
Changes (by robe):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 This looks like it's already addressed.
 http://postgis.net/docs/manual-3.0/ST_SetSRID.html
 I see it in the note:
 [Note]
 This function does not transform the geometry coordinates in any way - it
 simply sets the meta data defining the spatial reference system the
 geometry is assumed to be in. Use ST_Transform if you want to transform
 the geometry into a new projection.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4597#comment:1>
