[postgis-tickets] [PostGIS] #4483: Can't upgrade from PostGIS 3.0.0alpha3 to 3.0.0alpha4 or 3.0.0alpha5dev (ST_AsGeoJSON)
PostGIS trac at osgeo.org
Wed Feb 12 03:46:48 PST 2020
(ST_AsGeoJSON)
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  medium   |  Milestone:  PostGIS 3.0.1
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Changes (by strk):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 How was this fixed ? I'm still having it:
 strk=# select postgis_full_version();
 POSTGIS="3.1.0dev r3.1.0alpha1-3-gfc5392de7" [EXTENSION] PGSQL="96"
 GEOS="3.9.0dev-CAPI-1.14.0" SFCGAL="1.3.6" PROJ="7.0.0" GDAL="GDAL 3.0.4,
 released 2020/01/28" LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.2.1"
 WAGYU="0.4.3 (Internal)" (core procs from "3.0.0alpha3dev r17535" need
 upgrade) TOPOLOGY (topology procs from "3.0.0alpha5dev r17729" need
 upgrade) [UNPACKAGED!] RASTER (raster procs from "3.0.0alpha3dev r17535"
 need upgrade) (sfcgal procs from "3.0.0alpha3dev r17535" need upgrade)
 strk=# select postgis_extensions_upgrade();
 ERROR:  cannot change name of input parameter "pretty_print"
 HINT:  Use DROP FUNCTION st_asgeojson(record,text,integer,boolean) first.
 CONTEXT:  SQL statement "ALTER EXTENSION postgis UPDATE TO "3.1.0dev";"
 PL/pgSQL function postgis_extensions_upgrade() line 59 at EXECUTE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4483#comment:28>
