[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-8-g1bbc4cc
git at osgeo.org
git at osgeo.org
Wed Feb 12 07:17:55 PST 2020
the project "PostGIS".
via 1bbc4ccaa996033cc444f0eb149135e778451f74 (commit)
from abc6fd77a8240fe673f5a012a97eb62a950f085e (commit)
revisions in full, below.
commit 1bbc4ccaa996033cc444f0eb149135e778451f74
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Feb 12 15:49:05 2020 +0100
Revert "Try and be a little broader in dropping temporary old signature"
This reverts commit 548f6d1f953df7b56e69abbbdff72e33dcfdcff2.
Fixes #4483 and #4521 as far as I can tell
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index 0a5f266..fd104bc 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -168,7 +168,7 @@ SELECT _postgis_drop_function_if_needed
'ST_AsGeoJson',
- 'r record, geom_column text, maxdecimaldigits integer, pretty_print boolean'
+ $args$r record, geom_column text DEFAULT ''::text, maxdecimaldigits integer DEFAULT 15, pretty_print boolean DEFAULT false$args$
-- FUNCTION _st_orderingequals changed argument names in 3.0
Summary of changes:
postgis/postgis_before_upgrade.sql | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
