[postgis-tickets] [PostGIS] #4639: Can't upgrade from 3.0.0alpha3 to 3.1.0dev (cannot drop function pgis_geometry_union_transfn)
trac at osgeo.org
Wed Feb 12 09:00:37 PST 2020
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Resolution: | Keywords: upgrade
Comment (by Algunenano):
> If we dont support upgrades from alpha we should really not ship alphas
at all.
If shipping alphas means that we need to support them, then I'll -1 every
alpha/beta/rc release from now on. AFAIK, maybe I'm wrong, Postgis has
never offered support for development releases. We currently don't support
3.0.0alpha3, in the same exact way we don't support 2.2.
If you generate currently build 3.1 you don't get an upgrade path from
2.5.0alpha, 2.5.0beta1... to 3.1 and I think that's correct and the way to
go.
In fact, I think that we should have already removed the upgrade paths
from 3.0.0alphaX to 3.1 because it's not supported and you are not
supposed to do it.
IMO, there are 3 kinds of upgrades:
- Stable to stable: Should always work no matter what for supported
releases. Best effort for unsupported releases.
- Alpha/Beta/RC to next stable: Should work but it's also a best effort,
that is, they can't be a blocker in any way. If you find an issue you
should be able to report it and fix it, or decide it's not worth it and
nuke the database.
- Alpha/Beta/RC to other stable releases (not the immediate one after
those): There isn't a upgrade path available. You should go to the nearest
stable first and upgrade from there.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4639#comment:9>
