[postgis-tickets] [PostGIS] #4640: Update raster docs to explain why ST_Transform using alignment is important
trac at osgeo.org
Wed Feb 12 15:43:15 PST 2020
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.1
Component: documentation | Version: master
Resolution: | Keywords:
Description changed by robe:
Old description:
> This one is from IRC
> from - Maksim Gomov
> source data from - https://www.landfire.gov/fbfm40.php
New description:
from - Maksim Gomov
related thread from IRC
http://irclogs.geoapt.com/postgis/%23postgis.2020-02-12.log
22:14:31 reogl: hi all; I'm trying to transform a raster that's in
crs5070 to crs4326, but I am seeing gaps between the raster tiles when I
do that
22:15:53 reogl: i.e. https://i.imgur.com/OFTgXKN.png
22:16:21 reogl: (my query is a super simple ST_Transform(rast,
4326))
22:19:27 reogl: I assume it's related to the fact that 5070 is
geocentric while 4326 is geodetic, but I'm not sure how to mitigate this
on the postgis level (or if it's possible at all)
22:42:53 reogl: I'm wondering if I should just be reprojecting the
data before I import it into the db, but I'd prefer to save a few hours
and be able to do it on the db level rather than dropping it all
22:55:48 robe2: reogl when you are transforming multiple raster
tiles, you don't want to use ST_Transform(rast, srid) variant as you often
end up with misaligned tiles
22:56:20 robe2: I'm not sure if it will help your spacing issue, I
suspect it will -- if you use the ST_Transform(rast, alignto) variant
22:58:10 reogl: I'll give that a shot now, thanks; I'm also
looking at just reprojecting the whole dataset since we don't need it in
the db at 5070 anyways
23:02:01 robe2: Yah look at the
https://postgis.net/docs/RT_ST_Transform.html variant 3 example
23:02:03 sigq: Title: ST_Transform (at postgis.net)
23:02:27 robe2: Basically that foo -- you can just replace with
your table -- so you can skip the with foo part
23:05:17 reogl: yep, working on it now, thank you
23:06:18 robe2: We should have come up with a simpler to
understand example 3 - sorry -- not sure if I wrote that or Bborie -- I
blame Bborie cause he's not around :)
23:09:08 reogl: actually it's pretty straightforward to follow, I
am trying to coerce it into a table update statement now :)
23:27:23 reogl: and, by the way, the alignto method works as
expected
23:27:46 reogl: there are a few small artifacts but nothing that I
think will affect the data too much when I'm not operating on a pyramid
23:27:48 robe2: reogl so no gaps
23:27:52 reogl: correct
23:29:18 reogl: it would be nice if there was even just a 'gap'
keyword in the ST_Transform docs or something to point to the alignto form
of ST_Transform
23:29:48 reogl: (maybe it's my lack of knowledge about CRS and
geospatial stuff generally that's made me miss it though)
23:30:06 robe2: no it's a good point -- I'll add it
23:30:44 robe2: I think it was pretty unclear to me early on why
we needed an align to version -- so people are probably wondering what
that example 3 is for
23:31:00 reogl: here's the reprojected data; you can see some
small artifacting especially in the bottom left (the white spots) but for
my purposes this will be just fine https://i.imgur.com/BcIORRp.png
23:31:39 reogl: (and for all I know there is some similar
artifacting in the actual data ranges but it's not a concern for me right
now)
23:33:10 robe2: reogl -- is it okay if we use your screen shot in
manual
23:33:26 robe2: thinking visual would be better to explain the
difference
23:34:04 robe2: reogl and if you give me your full name I can
credit you
23:34:55 reogl: sure; Maksim Gomov
23:35:35 reogl: (the source data is fbfm40 from landfire if you
want to pull more examples)
23:36:04 reogl: https://www.landfire.gov/fbfm40.php
23:36:05 sigq: Title: LANDFIRE Program: Data Products - 40 Scott
and Burgan Fire Behavior Fuel Models (at www.landfire.gov)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4640#comment:2>
