[postgis-tickets] [PostGIS] #4642: regress_proj test fails with PROJ 7.0.0
trac at osgeo.org
Fri Feb 21 01:58:34 PST 2020
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.1
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by Algunenano):
I've built Proj master with Datumgrid 1.8 and it passes all the tests.
`PROJ4 version: 70`
I see in the release notes
(https://lists.osgeo.org/pipermail/proj/2020-February/009381.html) that it
has switched to use proj-data. I'm trying to download proj-data but the
download speed is pretty low and it's taking quite a bit of time.
I couldn't find exactly what to do with the file once I get it, I guess
place the contents under `/nad`?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4642#comment:2>
