[postgis-tickets] [PostGIS] #4643: PostgreSQL 13 no longer supports FROM in CREATE EXTENSION
trac at osgeo.org
Sat Feb 22 20:08:51 PST 2020
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Comment (by robe):
Thread from IRC
02:17:49 robe2: Komzpa good job except I don't see the release on
the dev mailing list though I do see it on users list
https://postgis.net/2020/02/20/postgis-3.0.1/
02:17:50 sigq: Title: PostGIS PostGIS 3.0.1 (at postgis.net)
02:18:12 robe2: Komzpa the exploding part yah that's not mentioned
in the HOW TO :) it wasn't always that way
02:18:48 robe2: that was my hack job to try to get something that
only works for PHP 5 / PHP 7 to work on PHP 7.3
03:59:42 robe2: RhodiumToad I assume this is an intentional
change? What replaces it? https://trac.osgeo.org/postgis/ticket/4643
03:59:43 sigq: Title: #4643 (PostgreSQL 13 no longer supports
FROM in CREATE EXTENSION) – PostGIS (at trac.osgeo.org)
04:04:18 RhodiumToad: FROM unpackaged is gone
04:04:51 RhodiumToad: without that, the only way to upgrade an
extenstion is from the version that's already installed, so no FROM option
is needed
04:04:51 robe2: RhodiumToad so how do people upgrade from
unpackaged?
04:05:33 robe2: oh so it's just CREATE EXTENSION postgis; and
system checks if the things are installed?
04:06:07 RhodiumToad: upgrading from unpackaged isn't supported
any more (from pg 13+)
04:06:38 robe2: :(
04:07:04 RhodiumToad: it gets in the way of allowing "trusted"
extensions which are installable by non-superusers
04:07:12 robe2: In PostGIS we have a function that upgrades old
version to new version so it's upgrade to the latest
04:07:46 RhodiumToad: commit 70a77320
04:07:47 robe2: and then the unpackaged step wraps these functions
in an extension
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4643#comment:2>
