[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-17-g9e40e8e
Tue Feb 25 02:01:45 PST 2020
the project "PostGIS".
       via  9e40e8e35795fab1553e52711a6f83d832dc62ba (commit)
      from  9a561c2f38e47d24188e3607fe4615203662f71f (commit)
revisions in full, below.
commit 9e40e8e35795fab1553e52711a6f83d832dc62ba
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Feb 25 10:31:14 2020 +0100
    Do not test FROM unpackaged upgrade paths with PostgreSQL >= 13
    See #4643
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 80b9231..f5fc9bb 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -115,23 +115,31 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
   done
   # Check unpackaged->extension upgrades
-  for majmin in `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`; do
-    UPGRADE_PATH="unpackaged${majmin}--${to_version_param}"
-    # only consider versions older than ${to_version_param}
-    cmp=`semver_compare "${majmin}" "${to_version_param}"`
-    if test $cmp -ge 0; then
-      echo "SKIP: upgrade $UPGRADE_PATH ($to_version_param is not newer than $majmin)"
-      continue
-    fi
-    echo "Testing ${EXT} upgrade $UPGRADE_PATH"
-    export RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH}"
-    make -C ${REGDIR} check && {
-      echo "PASS: upgrade $UPGRADE_PATH"
-      echo "FAIL: upgrade $UPGRADE_PATH"
-      failed
-  done
+  # NOTE: unsupported since PostgreSQL 13
+  #       See https://trac.osgeo.org/postgis/ticket/4643
+  export PGDATABASE=template1
+  pg_version_num=`psql -XAtc "SELECT current_setting('server_version_num')"` || exit 1
+  if test "$pg_version_num" -lt 130000; then
+    for majmin in `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`; do
+      UPGRADE_PATH="unpackaged${majmin}--${to_version_param}"
+      # only consider versions older than ${to_version_param}
+      cmp=`semver_compare "${majmin}" "${to_version_param}"`
+      if test $cmp -ge 0; then
+        echo "SKIP: upgrade $UPGRADE_PATH ($to_version_param is not newer than $majmin)"
+        continue
+      fi
+      echo "Testing ${EXT} upgrade $UPGRADE_PATH"
+      export RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH}"
+      make -C ${REGDIR} check && {
+        echo "PASS: upgrade $UPGRADE_PATH"
+        echo "FAIL: upgrade $UPGRADE_PATH"
+        failed
+    done
+  fi
 done
Summary of changes:
 utils/check_all_upgrades.sh | 42 +++++++++++++++++++++++++-----------------
 1 file changed, 25 insertions(+), 17 deletions(-)
hooks/post-receive
