[postgis-tickets] [PostGIS] #4646: Broken pointer arithmetic in gserialized_cmp leads crash/wrong results during ORDER BY
trac at osgeo.org
Wed Feb 26 10:35:29 PST 2020
during ORDER BY
Reporter: dkvash | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.5.4
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by dkvash):
Replying to [comment:2 Algunenano]:
> 2.4 is also flawed:
> if (
> sz1 > 16 && // 16 is size of EMPTY, if it's larger - it
has coordinates
> sz2 > 16 &&
> *(uint32_t*)(g1->data) == POINTTYPE &&
> *(uint32_t*)(g2->data) == POINTTYPE &&
> !FLAGS_GET_BBOX(g1->flags) &&
> !FLAGS_GET_GEODETIC(g1->flags) &&
> !FLAGS_GET_BBOX(g2->flags) &&
> !FLAGS_GET_GEODETIC(g2->flags)
> We shouldn't be dereferencing g1->data directly before checking if there
is a bbox (which is checked after). Let's reorder that and use
`gserialized_get_type` which already knows about the arithmetics.
> Also, 3.0+ is not affected as that function was refactored.
Have added patches for both minors: gserialized_cmp_fix_2_4_x.patch​ and
gserialized_cmp_fix_2_5_x.patch​
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4646#comment:3>
