[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 209be5f729b6878e04596612655e8f7974ecba8b
Fri Feb 28 09:20:52 PST 2020
the project "PostGIS".
The branch, stable-2.5 has been updated
       via  209be5f729b6878e04596612655e8f7974ecba8b (commit)
       via  77dcd7288bc944746480231a9bb177e53d7e5793 (commit)
       via  e7660a6ed1d26d7574ac0fd663eb2fac62f5ba40 (commit)
      from  e0122c555d635dbfa2f1dd8dc50a08a254260e75 (commit)
revisions in full, below.
commit 209be5f729b6878e04596612655e8f7974ecba8b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Feb 28 09:20:46 2020 -0800
    add last release note
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index b121e6e..f156b9d 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -31,7 +31,9 @@
         <para>4599, ST_AddPoint: Accept -1 as a valid position (Raúl Marín)</para>
         <para>4605, Fix postgis_upgrade.pl with PostgreSQL 12 (Matti Linnanvuori)</para>
         <para>4621, Prevent stack overflow when parsing WKB (Raúl Marín)</para>
-        <para>4626, Support pkg-config for libxml2 (Bas Couwenberg)  </para>
+        <para>4626, Support pkg-config for libxml2 (Bas Couwenberg)</para>
+        <para>4646, Fix gserialized_cmp incorrect comparison (dkvash)</para>
       </simplesect>
     </sect1>
commit 77dcd7288bc944746480231a9bb177e53d7e5793
Merge: e7660a6 e0122c5
Date:   Fri Feb 28 09:19:55 2020 -0800
    Merge branch 'stable-2.5' of https://git.osgeo.org/gitea/postgis/postgis into stable-2.5
commit e7660a6ed1d26d7574ac0fd663eb2fac62f5ba40
Date:   Fri Feb 28 09:19:39 2020 -0800
    prepare for 2.5.4 release
diff --git a/NEWS b/NEWS
index c2e4a2a..9854602 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 PostGIS 2.5.4
-2019/XX/XX
+2020/02/28
  * Bug fixes *
diff --git a/README.postgis b/README.postgis
index 7fbb2e5..9800427 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.5.2
-:Date: 2019-03-11
+:Version: 2.5.4
+:Date: 2020-02-28
 :Website: http://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 126a261..0ffdcff 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=2
 POSTGIS_MINOR_VERSION=5
-POSTGIS_MICRO_VERSION=4dev
+POSTGIS_MICRO_VERSION=4
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
index bd37130..b121e6e 100644
@@ -4,6 +4,38 @@
     <subtitle>Release Notes</subtitle>
     <sect1>
+      <title>Release 2.5.4</title>
+      <para>Release date: 2020/02/28</para>
+      <simplesect>
+        <title>Bug Fixes</title>
+        <para>4480, Geography Distance inconsistent with Intersects (Paul Ramsey)</para>
+        <para>4481, Improve libprotobuf detection for old systems (Paul Ramsey)</para>
+        <para>4475, Avoid reading into empty ptarray (Paul Ramsey)</para>
+        <para>4492, Fix ST_Simplify ignoring the value of the 3rd parameter (Raúl Marín)</para>
+        <para>4494, Fix ST_Simplify output having an outdated bbox (Raúl Marín)</para>
+        <para>4493, Fix ST_RemoveRepeatedPoints output having an outdated bbox (Raúl Marín)</para>
+        <para>4495, Fix ST_SnapToGrid output having an outdated bbox (Raúl Marín)</para>
+        <para>4496, Make ST_Simplify(TRIANGLE) collapse if requested (Raúl Marín)</para>
+        <para>4506, Remove tolerance in point-in-ring tests (Paul Ramsey)</para>
+        <para>4338, Fix Census block level data (tabblock table) loading (Regina Obe)</para>
+        <para>4519, Fix getSRIDbySRS crash (Raúl Marín)</para>
+        <para>4517, Documentation error ST_EndPoint (Samuel Spurling)</para>
+        <para>4530, Avoid bogus AddRasterConstraint in upgrade tests (Sandro Santilli)</para>
+        <para>4534, Fix leak in lwcurvepoly_from_wkb_state (Raúl Marín)</para>
+        <para>4536, Fix leak in lwcollection_from_wkb_state (Raúl Marín)</para>
+        <para>4537, Fix leak in WKT collection parser (Raúl Marín)</para>
+        <para>4547, Fix AddRasterConstraints handling of empty tables (Sandro Santilli)</para>
+        <para>4549, Fix schema qualification of internal types (Raúl Marín)</para>
+        <para>4546, Fix PLPGSQL functions missing the schema qualification (Raúl Marín)</para>
+        <para>4588, Fix update when st_union(geometry) doesn't exist (Raúl Marín)</para>
+        <para>4599, ST_AddPoint: Accept -1 as a valid position (Raúl Marín)</para>
+        <para>4605, Fix postgis_upgrade.pl with PostgreSQL 12 (Matti Linnanvuori)</para>
+        <para>4621, Prevent stack overflow when parsing WKB (Raúl Marín)</para>
+        <para>4626, Support pkg-config for libxml2 (Bas Couwenberg)  </para>
+      </simplesect>
+    </sect1>
+    <sect1>
       <title>Release 2.5.3</title>
       <para>Release date: 2019/08/11</para>
       <para>If compiling with PostgreSQL+JIT, LLVM >= 6 is required</para>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index c935c9f..d573a60 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -49,4 +49,5 @@ UPGRADEABLE_VERSIONS = \
 	2.5.0 \
 	2.5.1 \
 	2.5.2 \
-	2.5.3
+	2.5.3 \
+	2.5.4dev
Summary of changes:
 NEWS                               |  2 +-
 README.postgis                     |  4 ++--
 Version.config                     |  2 +-
 doc/release_notes.xml              | 34 ++++++++++++++++++++++++++++++++++
 extensions/upgradeable_versions.mk |  3 ++-
 5 files changed, 40 insertions(+), 5 deletions(-)
hooks/post-receive
