[postgis-tickets] [PostGIS] #4386: [upgrade] ERROR: cannot drop function st_union(geometry) because other objects depend on it
trac at osgeo.org
Fri Feb 28 15:46:37 PST 2020
Reporter: strk | Owner: komzpa
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Comment (by pramsey):
It was closed because the test wasn't exercising the new, bad behaviour,
but a long-standing, "shrug" behaviour, which is that if you have a view
based on ST_Union the upgrade process that does drop/create on aggregate
functions will fail on you.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4386#comment:16>
