[postgis-tickets] [PostGIS] #4750: Performance issue with computed columns
trac at osgeo.org
Sat Sep 5 14:42:47 PDT 2020
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.0.3
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by robe):
okay got excited too quickly. I have to recheck but it seemed like
1) Creating the new computed column and using it was fast 1 secs 208 ms
2) But then I ran the query against the old computed column and it too was
fast ` 1 secs 300 ms
3) Recreating the table and adding in the 2 new computed columns with the
index, and doing a vacuum (analyze,verbose) test.co_random_points.
Then running the query testing both computed columns, they are back to 30
secs to complete.
I'm going to revisit this to see if they become fast again. Maybe some
external process is fixing things.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4750#comment:2>
