[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-64-ga15f892
Mon Sep 7 21:35:30 PDT 2020
the project "PostGIS".
       via  a15f8921b434454f9264eb4de0dbe12ff79a0711 (commit)
      from  82d31f324dd8fa53446114684b465de43d5653fa (commit)
revisions in full, below.
commit a15f8921b434454f9264eb4de0dbe12ff79a0711
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Sep 8 00:35:09 2020 -0400
    Add test for computed columns references #4750 for PostGIS 3.1
diff --git a/regress/core/Makefile.in b/regress/core/Makefile.in
index b9df38b..d10b25e 100644
--- a/regress/core/Makefile.in
+++ b/regress/core/Makefile.in
@@ -175,6 +175,11 @@ TESTS_SLOW = \
 	concave_hull_hard \
 	knn_recheck
+ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" ">=" 120),1)
+	TESTS += \
+		computed_columns
+endif
 ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 37),1)
 	# GEOS-3.7 adds:
 	# ST_FrechetDistance
diff --git a/regress/core/computed_columns.sql b/regress/core/computed_columns.sql
new file mode 100644
index 0000000..b60b4e3
--- /dev/null
+++ b/regress/core/computed_columns.sql
@@ -0,0 +1,60 @@
+CREATE SCHEMA testc;
+CREATE OR REPLACE FUNCTION testc.compute_exection_time(param_sql text) RETURNS interval
+AS $$
+DECLARE var_start_time timestamptz; var_end_time timestamptz;
+BEGIN
+var_start_time = clock_timestamp();
+EXECUTE param_sql;
+var_end_time = clock_timestamp();
+RETURN var_end_time - var_start_time;
+END;
+$$ language plpgsql;
+CREATE TABLE testc.city_boundary AS
+SELECT ST_BuildArea(ST_Collect(geom)) As geom
+	FROM (SELECT ST_Translate(ST_SnapToGrid(ST_Buffer(ST_Point(50 ,generate_series(50,300, 100)
+			),100, 'quad_segs=4'),1), x, 0)  As geom
+			FROM generate_series(1,1000,100) As x)  AS foo;
+CREATE TABLE testc.streets AS
+WITH d AS (SELECT dp.geom FROM testc.city_boundary AS c, ST_DumpPoints(c.geom) AS dp)
+SELECT ROW_NUMBER() OVER() AS id, ST_MakeLine(d1.geom, d2.geom) AS geom
+FROM d AS d1, d AS d2
+ORDER BY d1.geom <-> d2.geom DESC LIMIT 1000;
+CREATE INDEX ix_streets_geom ON testc.streets USING GIST(geom);
+CREATE TABLE testc.random_points AS
+SELECT dp.path[1] AS id, dp.geom
+FROM testc.city_boundary AS c
+	, ST_GeneratePoints(c.geom,500) AS gp
+	, ST_DumpPoints(gp) AS dp;
+ALTER TABLE testc.random_points
+    ADD CONSTRAINT PK_random_points
+    PRIMARY KEY (id);
+CREATE INDEX gix_random_points_geom
+    ON testc.random_points USING GIST (geom);
+    ADD way_buffer GEOMETRY (POLYGON)
+    GENERATED ALWAYS AS (ST_Buffer(geom, 500)) STORED ;
+CREATE INDEX gix_random_way_buffer_geom
+    ON testc.random_points USING GIST (way_buffer);
+analyze testc.random_points;
+analyze testc.streets;
+-- time using computed column should always be less than adhoc
+SELECT testc.compute_exection_time('SELECT COUNT(*) FROM testc.random_points AS p INNER JOIN testc.streets AS s ON ST_Contains(p.way_buffer, s.geom)') <
+testc.compute_exection_time('SELECT COUNT(*) FROM testc.random_points AS p INNER JOIN testc.streets AS s ON ST_Contains(ST_Buffer(p.geom, 500), s.geom);');
+-- confirm results are the same
+SELECT (SELECT COUNT(*) FROM testc.random_points AS p INNER JOIN testc.streets AS s ON ST_Contains(p.way_buffer, s.geom) ) =
+ (SELECT COUNT(*) FROM testc.random_points AS p INNER JOIN testc.streets AS s ON ST_Contains(ST_Buffer(p.geom, 500), s.geom) );
+-- cleanup
+DROP SCHEMA testc CASCADE;
diff --git a/regress/core/computed_columns_expected b/regress/core/computed_columns_expected
index 0000000..a40bacf
--- /dev/null
+++ b/regress/core/computed_columns_expected
@@ -0,0 +1,3 @@
+t
+t
+NOTICE:  drop cascades to 4 other objects
Summary of changes:
 regress/core/Makefile.in               |  5 +++
 regress/core/computed_columns.sql      | 60 ++++++++++++++++++++++++++++++++++
 regress/core/computed_columns_expected |  3 ++
 3 files changed, 68 insertions(+)
 create mode 100644 regress/core/computed_columns.sql
 create mode 100644 regress/core/computed_columns_expected
hooks/post-receive
