[postgis-tickets] [PostGIS] #4754: Performance difference with versions of Postgres/Postgis
trac at osgeo.org
Thu Sep 10 00:25:14 PDT 2020
Reporter: fractalf | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS PostgreSQL
Component: postgis | Version: 3.0.x
Keywords: |
Hi community!
I'd like to register an issue with Postgis regarding performance in
different versions of Postgres/Postgis.
I'm testing this out before we build a full solution and got some strange
different response times running a query on different versions.
I test this in docker using 3 setups:
**1.**
FROM postgres:11.9
ENV POSTGIS_MAJOR 3
ENV POSTGIS_VERSION 3.0.2+dfsg-2.pgdg90+1
=> This gives me a response time of about **0.05s**
**2.**
FROM postgres:12
ENV POSTGIS_MAJOR 3
ENV POSTGIS_VERSION 3.0.2+dfsg-2.pgdg100+1
=> This gives me a response time of about **0.5s**
**3.**
FROM postgres:12
ENV POSTGIS_MAJOR 2.5
ENV POSTGIS_VERSION 2.5.5+dfsg-1.pgdg100+1
I found this huge increase (almost 10x) in response time very strange.
This is more or less my test data/query:
CREATE TABLE "zones" (
"id" serial NOT NULL,
"name" character varying NOT NULL,
"geo" geometry NOT NULL
CREATE TABLE "points" (
INSERT INTO zones (name, geo) VALUES
('Foo', 'POLYGON(
63.43277965483068 10.354270935058594,
63.43009239981209 10.353584289550781,
63.42533150079501 10.367660522460936,
63.421337878804195 10.386199951171873,
63.40474303024033 10.385856628417969,
63.394904513399645 10.387916564941406,
63.4155000456553 10.458297729492186,
63.428403139082626 10.472373962402344,
63.43945831122457 10.46945571899414,
63.44759342069812 10.462932586669922,
63.45035576238835 10.45074462890625,
63.44797709520402 10.42276382446289,
63.44053289210481 10.398731231689453,
63.434008030326964 10.362682342529297,
# Insert 10000 random points from a generated sql file
select count(*)
from points as p
join zones as z
on ST_WITHIN(p.geo, z.geo)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4754>
