[postgis-tickets] [PostGIS] #4825: Memory Leak with ST_MakeValid() and invalid geometry?
trac at osgeo.org
Tue Jan 5 04:06:27 PST 2021
Reporter: neumann | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.1
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by strk):
I can't restore with PostgreSQL-12 either. If I understand the message
correctly the backup was taking with PostgreSQL-14 (!). Is there any
chance you can produce an SQL dump instead, for ease of access ? Or a dump
with an earlier version of PostgreSQL ? (ideally not newer than 10)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4825#comment:4>
