[postgis-tickets] [PostGIS] #4684: concurrent topology construction routine may result in invalid topology
PostGIS trac at osgeo.org
Mon Jan 11 07:38:18 PST 2021
  Reporter:  laopsahl  |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.0.4
 Component:  topology  |    Version:  3.0.x
Resolution:            |   Keywords:
Comment (by strk):
 In order to have a clearer picture of what's going wrong, I'v efixed #3233
 (ValidateTopology check on node's containing_face) - This only affects
 topologies with isolated nodes, so not necessarely something you can test,
 but you could maybe run some performance comparison as I bet
 ValidateTopology will now be much slower.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4684#comment:23>
