[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-44-gd138985
git at osgeo.org
git at osgeo.org
Tue Jan 12 09:10:19 PST 2021
the project "PostGIS".
via d138985015bd56a21bc6d9f5b5c301528e7155a6 (commit)
from ebe9ec54cfb2a5f3345a6a861961de63bb1ddf52 (commit)
revisions in full, below.
commit d138985015bd56a21bc6d9f5b5c301528e7155a6
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Jan 12 15:19:08 2021 +0100
Check isolated edges are covered by their left-right faces
Updates existing tests accordingly.
Includes NEWS item.
Closes #4830
diff --git a/NEWS b/NEWS
index 318c8ad..6b80230 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,8 @@ PostGIS 3.2.0
* Enhancements *
- #3233, ValidateTopology check for node's containing_face (Sandro Santilli)
+ - #4830, ValidateTopology check for edges side face containment
+ (Sandro Santilli)
PostGIS 3.1.0
2020/12/18
diff --git a/topology/test/regress/legacy_invalid_expected b/topology/test/regress/legacy_invalid_expected
index e47d167..a01114e 100644
--- a/topology/test/regress/legacy_invalid_expected
+++ b/topology/test/regress/legacy_invalid_expected
@@ -19,4 +19,6 @@ face has no rings|10|
face within face|11|2
face overlaps face|2|12
not-isolated node has not-null containing_face|4|
+edge not covered by both its side faces|28|
+edge not covered by both its side faces|30|
Topology 'invalid_topology' dropped
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 2943854..d6710f8 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1709,6 +1709,41 @@ BEGIN
RETURN NEXT retrec;
END LOOP;
+ -- Check edges are covered by their left-right faces (#4831)
+ FOR rec IN EXECUTE format(
+ $SQL$
+ WITH edge_coverage AS (
+ SELECT
+ e.edge_id,
+ e.left_face,
+ ST_Covers(fl.geom, e.geom) covered_left,
+ e.right_face,
+ ST_Covers(fr.geom, e.geom) covered_right
+ FROM
+ %1$I.edge_data e
+ LEFT JOIN face_check fl ON ( fl.face_id = e.left_face )
+ LEFT JOIN face_check fr ON ( fr.face_id = e.right_face )
+ WHERE
+ -- isolated only
+ e.next_left_edge = e.edge_id
+ AND
+ e.next_right_edge = e.edge_id
+ -- skip invalid edges (will be already reported previously)
+ AND NOT e.edge_id = ANY(%2$L)
+ SELECT * from edge_coverage
+ WHERE
+ NOT covered_left
+ OR NOT covered_right
+ ORDER BY edge_id
+ $SQL$, toponame, invalid_edges)
+ LOOP
+ retrec.error := 'edge not covered by both its side faces';
+ retrec.id1 := rec.edge_id;
+ retrec.id2 := NULL; -- TODO: write expected containing_face here ?
+ RETURN NEXT retrec;
+ END LOOP;
DROP TABLE face_check;
RETURN;
Summary of changes:
NEWS | 2 ++
topology/test/regress/legacy_invalid_expected | 2 ++
topology/topology.sql.in | 35 +++++++++++++++++++++++++++
3 files changed, 39 insertions(+)
hooks/post-receive
