[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-692-g3af56023f
Mon Apr 4 19:44:01 PDT 2022
the project "PostGIS".
       via  3af56023fd1c70168e555364562d7c950ec8e34b (commit)
      from  c9c75d1b54eede92bc8437a11b2ce56531988c52 (commit)
revisions in full, below.
commit 3af56023fd1c70168e555364562d7c950ec8e34b
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Apr 4 22:43:48 2022 -0400
    Fix compile against PG15. References #5123 for PostGIS 3.3
diff --git a/NEWS b/NEWS
index bf49a58cb..64fdb4664 100644
--- a/NEWS
+++ b/NEWS
@@ -20,16 +20,19 @@ PostGIS 3.3.0dev
   - GH657, GiST: do not call no-op decompress function (Aliaksandr Kalenik)
   - #4912, GiST: fix crash on STORAGE EXTERNAL for geography (Aliaksandr Kalenik)
   - ST_ConcaveHull GEOS 3.11+ native implementation (Paul Ramsey, Martin Davis)
-  - #5100, Support for PostgreSQL 15 (atoi removal) (Laurenz Albe)
   - GH678, Enable Link-Time Optimizations by default if supported (Sergei Shoulbakov)
- * New features*
+ * New features *
   - ST_Letters creates geometries that look like letters (Paul Ramsey)
   - #5037, postgis_sfcgal: ST_3DConvexHull (Loïc Bartoletti)
   - postgis_sfcgal: sfcgal_full_version - reports BOOST and CGAL version
     (Loïc Bartoletti)
   - GH659, MARC21/XML, ST_GeomFromMARC21, ST_AsMARC21 (Jim Jones)
+ * Bug Fix *
+   - #5100, Support for PostgreSQL 15 (atoi removal) (Laurenz Albe)
+   - #5123, PG15 now exposes json types and functions, no need
+    to include for PG15+ (Regina Obe)
 PostGIS 3.2.0 (Olivier Courtin Edition)
diff --git a/postgis/lwgeom_out_geojson.c b/postgis/lwgeom_out_geojson.c
index fcedef70f..f61a5609a 100644
--- a/postgis/lwgeom_out_geojson.c
+++ b/postgis/lwgeom_out_geojson.c
@@ -32,7 +32,7 @@
 #include "lwgeom_log.h"
 #include "liblwgeom.h"
+#if POSTGIS_PGSQL_VERSION < 150
 typedef enum					/* type categories for datum_to_json */
 	JSONTYPE_NULL,				/* null, so we didn't bother to identify */
@@ -47,6 +47,7 @@ typedef enum					/* type categories for datum_to_json */
 	JSONTYPE_CAST,				/* something with an explicit cast to JSON */
 	JSONTYPE_OTHER				/* all else */
 } JsonTypeCategory;
+#endif
 static void array_dim_to_json(StringInfo result, int dim, int ndims, int *dims,
 				  Datum *vals, bool *nulls, int *valcount,
@@ -67,9 +68,11 @@ static void composite_to_json(Datum composite, StringInfo result,
 static void datum_to_json(Datum val, bool is_null, StringInfo result,
 						  JsonTypeCategory tcategory, Oid outfuncoid,
 						  bool key_scalar);
 static void json_categorize_type(Oid typoid,
 								 JsonTypeCategory *tcategory,
 								 Oid *outfuncoid);
+#endif
 static char * postgis_JsonEncodeDateTime(char *buf, Datum value, Oid typid);
 static int postgis_time2tm(TimeADT time, struct pg_tm *tm, fsec_t *fsec);
 static int postgis_timetz2tm(TimeTzADT *time, struct pg_tm *tm, fsec_t *fsec, int *tzp);
@@ -231,6 +234,7 @@ composite_to_geojson(FunctionCallInfo fcinfo,
  * json.c from the Postgres source tree as of 2019-03-28.
  * It would be far better if these were exported from the
  * backend so we could just use them here. Maybe someday.
+ * Sequel: 2022-04-04 That some day finally came in PG15
@@ -240,6 +244,7 @@ composite_to_geojson(FunctionCallInfo fcinfo,
  * output function OID.  If the returned category is JSONTYPE_CAST, we
  * return the OID of the type->JSON cast function instead.
 static void
@@ -731,3 +736,4 @@ postgis_JsonEncodeDateTime(char *buf, Datum value, Oid typid)
 	return buf;
+#endif
Summary of changes:
 NEWS                         | 7 +++++--
 postgis/lwgeom_out_geojson.c | 8 +++++++-
 2 files changed, 12 insertions(+), 3 deletions(-)
hooks/post-receive
