[postgis-tickets] [PostGIS] #5123: PostgreSQL 15 build is broken - jsonb failures
trac at osgeo.org
Mon Apr 4 21:05:20 PDT 2022
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.3.0
Component: postgis | Version: 3.2.x
Resolution: | Keywords:
Comment (by robe):
okay this still needs some work, now getting error:
23:51:56 psql:/var/lib/jenkins/workspace/postgis/branches/3.3/regress/00
-regress-install/share/contrib/postgis/postgis.sql:4796: ERROR: syntax
error at or near "("
23:51:56 LINE 1: CREATE OR REPLACE FUNCTION json(geometry)
23:51:56 ^
23:51:56
23:51:56 failed (Error encountered loading
/var/lib/jenkins/workspace/postgis/branches/3.3/regress/00-regress-
install/share/contrib/postgis/postgis_comments.sql:
/var/lib/jenkins/workspace/postgis/tmp/3_3_pg15w64/regress_log)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5123#comment:3>
