[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-696-g83faf96fc
git at osgeo.org
git at osgeo.org
Tue Apr 5 17:28:11 PDT 2022
the project "PostGIS".
via 83faf96fc252504ada28bd07ba86c4ba6b31aa5a (commit)
from 9b582b348a89dac43a5fe7c36c59b1973c32c4bf (commit)
revisions in full, below.
commit 83faf96fc252504ada28bd07ba86c4ba6b31aa5a
Author: Regina Obe <lr at pcorp.us>
Date: Tue Apr 5 20:28:05 2022 -0400
Fix compile against PG15. json and jsonb are now keywords so must be quoted as function names. References #5123 for PostGIS 3.3
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index c0a206059..115155764 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4866,23 +4866,23 @@ CREATE OR REPLACE FUNCTION ST_AsGeoJson(r record, geom_column text DEFAULT '', m
_COST_MEDIUM;
-- Availability: 3.0.0
-CREATE OR REPLACE FUNCTION json(geometry)
+CREATE OR REPLACE FUNCTION "json"(geometry)
RETURNS json
AS 'MODULE_PATHNAME','geometry_to_json'
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION jsonb(geometry)
+CREATE OR REPLACE FUNCTION "jsonb"(geometry)
RETURNS jsonb
AS 'MODULE_PATHNAME','geometry_to_jsonb'
_COST_MEDIUM;
-CREATE CAST (geometry AS json) WITH FUNCTION json(geometry);
+CREATE CAST (geometry AS json) WITH FUNCTION "json"(geometry);
-CREATE CAST (geometry AS jsonb) WITH FUNCTION jsonb(geometry);
+CREATE CAST (geometry AS jsonb) WITH FUNCTION "jsonb"(geometry);
-- Mapbox Vector Tile OUTPUT
Summary of changes:
postgis/postgis.sql.in | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
