[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-701-gd61f094d7
git at osgeo.org
git at osgeo.org
Wed Apr 6 07:35:32 PDT 2022
the project "PostGIS".
via d61f094d7c76e2c2472b39a98db6c969e9c6e512 (commit)
from cdf8d0238e7d2a5959503b2835bf9be15aefe061 (commit)
revisions in full, below.
commit d61f094d7c76e2c2472b39a98db6c969e9c6e512
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Apr 6 16:31:59 2022 +0200
Put AddTopoGeometryColumn code in its own file
diff --git a/topology/sql/manage/AddTopoGeometryColumn.sql.in b/topology/sql/manage/AddTopoGeometryColumn.sql.in
new file mode 100644
index 000000000..514feaa93
--- /dev/null
+++ b/topology/sql/manage/AddTopoGeometryColumn.sql.in
@@ -0,0 +1,184 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright (C) 2022 Sandro Santilli <strk at kbt.io>
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+-- AddTopoGeometryColumn(toponame, schema, table, colum, type, [child])
+-- Add a TopoGeometry column to a table, making it a topology layer.
+-- Returns created layer id.
+-- Availability: 1.1.0
+CREATE OR REPLACE FUNCTION topology.AddTopoGeometryColumn(toponame varchar, schema varchar, tbl varchar, col varchar, ltype varchar, child integer)
+ RETURNS integer
+AS
+DECLARE
+ intltype integer;
+ newlevel integer;
+ topoid integer;
+ rec RECORD;
+ newlayer_id integer;
+ query text;
+BEGIN
+ -- Get topology id
+ SELECT id INTO topoid
+ FROM topology.topology WHERE name = toponame;
+ IF NOT FOUND THEN
+ RAISE EXCEPTION 'Topology % does not exist', quote_literal(toponame);
+ END IF;
+ IF ltype ILIKE '%POINT%' OR ltype ILIKE 'PUNTAL' THEN
+ intltype = 1;
+ ELSIF ltype ILIKE '%LINE%' OR ltype ILIKE 'LINEAL' THEN
+ intltype = 2;
+ ELSIF ltype ILIKE '%POLYGON%' OR ltype ILIKE 'AREAL' THEN
+ intltype = 3;
+ ELSIF ltype ILIKE '%COLLECTION%' OR ltype ILIKE 'GEOMETRY' THEN
+ intltype = 4;
+ ELSE
+ RAISE EXCEPTION 'Layer type must be one of POINT,LINE,POLYGON,COLLECTION';
+ END IF;
+ -- Add new TopoGeometry column in schema.table
+ EXECUTE 'ALTER TABLE ' || quote_ident(schema)
+ || '.' || quote_ident(tbl)
+ || ' ADD COLUMN ' || quote_ident(col)
+ || ' topology.TopoGeometry;';
+ -- See if child id exists and extract its level
+ IF child IS NOT NULL THEN
+ SELECT level + 1 FROM topology.layer
+ WHERE layer_id = child
+ AND topology_id = topoid
+ INTO newlevel;
+ IF newlevel IS NULL THEN
+ RAISE EXCEPTION 'Child layer % does not exist in topology "%"', child, toponame;
+ END IF;
+ END IF;
+ -- Get new layer id from sequence
+ EXECUTE 'SELECT nextval(' ||
+ quote_literal(
+ quote_ident(toponame) || '.layer_id_seq'
+ ) || ')' INTO STRICT newlayer_id;
+ EXECUTE 'INSERT INTO '
+ 'topology.layer(topology_id, '
+ 'layer_id, level, child_id, schema_name, '
+ 'table_name, feature_column, feature_type) '
+ 'VALUES ('
+ || topoid || ','
+ || newlayer_id || ',' || COALESCE(newlevel, 0) || ','
+ || COALESCE(child::text, 'NULL') || ','
+ || quote_literal(schema) || ','
+ || quote_literal(tbl) || ','
+ || quote_literal(col) || ','
+ || intltype || ');';
+ -- Create a sequence for TopoGeometries in this new layer
+ EXECUTE 'CREATE SEQUENCE ' || quote_ident(toponame)
+ || '.topogeo_s_' || newlayer_id;
+ -- Add constraints on TopoGeom column
+ || ' ADD CONSTRAINT "check_topogeom_' || col || '" CHECK ('
+ 'topology_id(' || quote_ident(col) || ') = ' || topoid
+ || ' AND '
+ 'layer_id(' || quote_ident(col) || ') = ' || newlayer_id
+ || ' AND '
+ 'type(' || quote_ident(col) || ') = ' || intltype
+ -- Add dependency of the feature column on the topology schema
+ query = 'INSERT INTO pg_catalog.pg_depend SELECT '
+ 'fcat.oid, fobj.oid, fsub.attnum, tcat.oid, '
+ 'tobj.oid, 0, ''n'' '
+ 'FROM pg_class fcat, pg_namespace fnsp, '
+ ' pg_class fobj, pg_attribute fsub, '
+ ' pg_class tcat, pg_namespace tobj '
+ ' WHERE fcat.relname = ''pg_class'' '
+ ' AND fnsp.nspname = ' || quote_literal(schema)
+ || ' AND fobj.relnamespace = fnsp.oid '
+ ' AND fobj.relname = ' || quote_literal(tbl)
+ || ' AND fsub.attrelid = fobj.oid '
+ ' AND fsub.attname = ' || quote_literal(col)
+ || ' AND tcat.relname = ''pg_namespace'' '
+ ' AND tobj.nspname = ' || quote_literal(toponame);
+-- The only reason to add this dependency is to avoid
+-- simple drop of a feature column. Still, drop cascade
+-- will remove both the feature column and the sequence
+-- corrupting the topology anyway ...
+#if 0
+ -- Add dependency of the topogeom sequence on the feature column
+ -- This is a dirty hack ...
+ 'scat.oid, sobj.oid, 0, fcat.oid, '
+ 'fobj.oid, fsub.attnum, ''n'' '
+ ' pg_class scat, pg_class sobj, '
+ ' pg_namespace snsp '
+ || ' AND scat.relname = ''pg_class'' '
+ ' AND snsp.nspname = ' || quote_literal(toponame)
+ || ' AND sobj.relnamespace = snsp.oid '
+ ' AND sobj.relname = '
+ ' ''topogeo_s_' || newlayer_id || ''' ';
+ RAISE NOTICE '%', query;
+ EXECUTE query;
+#endif
+ RETURN newlayer_id;
+END;
+LANGUAGE 'plpgsql' VOLATILE;
+--}{ AddTopoGeometryColumn
+CREATE OR REPLACE FUNCTION topology.AddTopoGeometryColumn(varchar, varchar, varchar, varchar, varchar)
+ RETURNS integer
+AS
+ SELECT topology.AddTopoGeometryColumn($1, $2, $3, $4, $5, NULL);
+LANGUAGE 'sql' VOLATILE;
+--} AddTopoGeometryColumn
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 50f408d38..553e8c1b5 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -536,177 +536,6 @@ $$
LANGUAGE 'plpgsql' VOLATILE STRICT;
--} RelationTrigger()
--- AddTopoGeometryColumn(toponame, schema, table, colum, type, [child])
--- Add a TopoGeometry column to a table, making it a topology layer.
--- Returns created layer id.
--- Availability: 1.1.0
-CREATE OR REPLACE FUNCTION topology.AddTopoGeometryColumn(toponame varchar, schema varchar, tbl varchar, col varchar, ltype varchar, child integer)
- RETURNS integer
-AS
-DECLARE
- intltype integer;
- newlevel integer;
- topoid integer;
- rec RECORD;
- newlayer_id integer;
- query text;
-BEGIN
- -- Get topology id
- SELECT id INTO topoid
- FROM topology.topology WHERE name = toponame;
- IF NOT FOUND THEN
- RAISE EXCEPTION 'Topology % does not exist', quote_literal(toponame);
- END IF;
- IF ltype ILIKE '%POINT%' OR ltype ILIKE 'PUNTAL' THEN
- intltype = 1;
- ELSIF ltype ILIKE '%LINE%' OR ltype ILIKE 'LINEAL' THEN
- intltype = 2;
- ELSIF ltype ILIKE '%POLYGON%' OR ltype ILIKE 'AREAL' THEN
- intltype = 3;
- ELSIF ltype ILIKE '%COLLECTION%' OR ltype ILIKE 'GEOMETRY' THEN
- intltype = 4;
- ELSE
- RAISE EXCEPTION 'Layer type must be one of POINT,LINE,POLYGON,COLLECTION';
- END IF;
- -- Add new TopoGeometry column in schema.table
- EXECUTE 'ALTER TABLE ' || quote_ident(schema)
- || '.' || quote_ident(tbl)
- || ' ADD COLUMN ' || quote_ident(col)
- || ' topology.TopoGeometry;';
- -- See if child id exists and extract its level
- IF child IS NOT NULL THEN
- SELECT level + 1 FROM topology.layer
- WHERE layer_id = child
- AND topology_id = topoid
- INTO newlevel;
- IF newlevel IS NULL THEN
- RAISE EXCEPTION 'Child layer % does not exist in topology "%"', child, toponame;
- END IF;
- END IF;
- -- Get new layer id from sequence
- EXECUTE 'SELECT nextval(' ||
- quote_literal(
- quote_ident(toponame) || '.layer_id_seq'
- ) || ')' INTO STRICT newlayer_id;
- EXECUTE 'INSERT INTO '
- 'topology.layer(topology_id, '
- 'layer_id, level, child_id, schema_name, '
- 'table_name, feature_column, feature_type) '
- 'VALUES ('
- || topoid || ','
- || newlayer_id || ',' || COALESCE(newlevel, 0) || ','
- || COALESCE(child::text, 'NULL') || ','
- || quote_literal(schema) || ','
- || quote_literal(tbl) || ','
- || quote_literal(col) || ','
- || intltype || ');';
- -- Create a sequence for TopoGeometries in this new layer
- EXECUTE 'CREATE SEQUENCE ' || quote_ident(toponame)
- || '.topogeo_s_' || newlayer_id;
- -- Add constraints on TopoGeom column
- || ' ADD CONSTRAINT "check_topogeom_' || col || '" CHECK ('
- 'topology_id(' || quote_ident(col) || ') = ' || topoid
- || ' AND '
- 'layer_id(' || quote_ident(col) || ') = ' || newlayer_id
- || ' AND '
- 'type(' || quote_ident(col) || ') = ' || intltype
- -- Add dependency of the feature column on the topology schema
- query = 'INSERT INTO pg_catalog.pg_depend SELECT '
- 'fcat.oid, fobj.oid, fsub.attnum, tcat.oid, '
- 'tobj.oid, 0, ''n'' '
- 'FROM pg_class fcat, pg_namespace fnsp, '
- ' pg_class fobj, pg_attribute fsub, '
- ' pg_class tcat, pg_namespace tobj '
- ' WHERE fcat.relname = ''pg_class'' '
- ' AND fnsp.nspname = ' || quote_literal(schema)
- || ' AND fobj.relnamespace = fnsp.oid '
- ' AND fobj.relname = ' || quote_literal(tbl)
- || ' AND fsub.attrelid = fobj.oid '
- ' AND fsub.attname = ' || quote_literal(col)
- || ' AND tcat.relname = ''pg_namespace'' '
- ' AND tobj.nspname = ' || quote_literal(toponame);
--- The only reason to add this dependency is to avoid
--- simple drop of a feature column. Still, drop cascade
--- will remove both the feature column and the sequence
--- corrupting the topology anyway ...
-#if 0
- -- Add dependency of the topogeom sequence on the feature column
- -- This is a dirty hack ...
- 'scat.oid, sobj.oid, 0, fcat.oid, '
- 'fobj.oid, fsub.attnum, ''n'' '
- ' pg_class scat, pg_class sobj, '
- ' pg_namespace snsp '
- || ' AND scat.relname = ''pg_class'' '
- ' AND snsp.nspname = ' || quote_literal(toponame)
- || ' AND sobj.relnamespace = snsp.oid '
- ' AND sobj.relname = '
- ' ''topogeo_s_' || newlayer_id || ''' ';
- RAISE NOTICE '%', query;
- EXECUTE query;
-#endif
- RETURN newlayer_id;
-END;
-LANGUAGE 'plpgsql' VOLATILE;
---}{ AddTopoGeometryColumn
-CREATE OR REPLACE FUNCTION topology.AddTopoGeometryColumn(varchar, varchar, varchar, varchar, varchar)
- RETURNS integer
-AS
- SELECT topology.AddTopoGeometryColumn($1, $2, $3, $4, $5, NULL);
-LANGUAGE 'sql' VOLATILE;
---} AddTopoGeometryColumn
-- DropTopoGeometryColumn(schema, table, colum)
@@ -1580,6 +1409,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
--general management --
#include "sql/manage/ManageHelper.sql.in"
+#include "sql/manage/AddTopoGeometryColumn.sql.in"
#include "sql/manage/CreateTopology.sql.in"
#include "sql/manage/TopologySummary.sql.in"
#include "sql/manage/CopyTopology.sql.in"
Summary of changes:
topology/sql/manage/AddTopoGeometryColumn.sql.in | 184 +++++++++++++++++++++++
topology/topology.sql.in | 172 +--------------------
2 files changed, 185 insertions(+), 171 deletions(-)
create mode 100644 topology/sql/manage/AddTopoGeometryColumn.sql.in
hooks/post-receive
