[postgis-tickets] [PostGIS] #5125: Creating both topology and tiger extension in same session contend search_path
PostGIS trac at osgeo.org
Fri Apr 8 02:41:05 PDT 2022
search_path
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 I've implemented the above idea and pushed to master branch.
 Do you think it should be backported ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5125#comment:4>
