[postgis-tickets] [PostGIS] #5130: installcheck rule runs topology tests twice (second time without --extension)
trac at osgeo.org
Mon Apr 11 14:59:42 PDT 2022
--extension)
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Comment (by strk):
I found the problem being {{{ make installcheck RUNTESTFLAGS=-v }}} as NOT
passing a RUNTESTFLAGS is not a problem in master branch either. With
RUNTESTFLAGS=-v passed, not only --extension disappears, but also
--upgrade and --upgrade-path.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5130#comment:2>
