[postgis-tickets] [PostGIS] #5131: Upgrading extension from 3.2.1dev puts tiger twice in session search_path
trac at osgeo.org
Tue Apr 12 01:53:16 PDT 2022
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: build/upgrade/install | Version: master
Keywords: |
xxx=# create extension postgis_topology version '3.2.1dev' cascade;
NOTICE: installing required extension "postgis"
CREATE EXTENSION
xxx=# create extension postgis_tiger_geocoder version '3.2.1dev' cascade;
NOTICE: installing required extension "fuzzystrmatch"
CREATE EXTENSION
xxx=# show search_path; -- known issue
search_path
"$user", public, tiger
(1 row)
xxx=# \c
You are now connected to database "xxx" as user "strk".
search_path
(1 row)
xxx=# select postgis_extensions_upgrade();
NOTICE: Updating extension postgis 3.3.0dev
NOTICE: Updating extension postgis_topology 3.2.1dev
NOTICE: Updating extension postgis_tiger_geocoder 3.2.1dev
Upgrade to version 3.3.0dev completed, run SELECT postgis_full_version();
for details
(1 row)
xxx=# show search_path; -- THIS issue
search_path
tiger, "$user", public, tiger
(1 row)
xxx=# \c
xxx=# show search_path; -- we're OK after reconnect
search_path
"$user", public, tiger, topology
(1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5131>
