[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-721-g2eb420ed4
git at osgeo.org
git at osgeo.org
Thu Apr 14 09:04:54 PDT 2022
the project "PostGIS".
via 2eb420ed4f3defb28e496330dc03520f41b7680a (commit)
from 88c205f24beb22c37e7eecb2caefaa443db82df9 (commit)
revisions in full, below.
commit 2eb420ed4f3defb28e496330dc03520f41b7680a
Author: Martin Davis <mtnclimb at gmail.com>
Date: Thu Apr 14 09:04:49 2022 -0700
Fix doc ST_PointM typo, descriptions
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 8a4f19e2d..ef1c1bfff 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -644,7 +644,7 @@ FROM provinces p;
<refnamediv>
<refname>ST_Point</refname>
- <refpurpose>Creates a Point with the given coordinate values. Alias for ST_MakePoint.</refpurpose>
+ <refpurpose>Creates a Point with X, Y and SRID values.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -668,7 +668,7 @@ FROM provinces p;
<refsection>
<title>Description</title>
- <para>Returns an Point with the given X and Y coordinate values. This is the SQL-MM alias for <xref linkend="ST_MakePoint" /> that takes just X and Y.</para>
+ <para>Returns a Point with the given X and Y coordinate values. This is the SQL-MM equivalent for <xref linkend="ST_MakePoint" /> that takes just X and Y.</para>
<note><para>For geodetic coordinates, <varname>X</varname> is longitude and <varname>Y</varname> is latitude</para></note>
@@ -718,7 +718,7 @@ SELECT ST_Transform(ST_SetSRID( ST_Point( 3637510, 3014852 ), 2273), 4326)::geog
<refentry id="ST_PointZ">
<refnamediv>
<refname>ST_PointZ</refname>
- <refpurpose>Creates a Point with the given coordinate and SRID values.</refpurpose>
+ <refpurpose>Creates a Point with X, Y, Z and SRID values.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -755,13 +755,13 @@ SELECT ST_Transform(ST_SetSRID( ST_Point( 3637510, 3014852 ), 2273), 4326)::geog
<refentry id="ST_PointM">
<refnamediv>
<refname>ST_PointM</refname>
+ <refpurpose>Creates a Point with X, Y, M and SRID values.</refpurpose>
</refnamediv>
<refsynopsisdiv>
<funcsynopsis>
<funcprototype>
- <funcdef>geometry <function>ST_PointZ</function></funcdef>
+ <funcdef>geometry <function>ST_PointM</function></funcdef>
<paramdef><type>float</type> <parameter>x</parameter></paramdef>
<paramdef><type>float</type> <parameter>y</parameter></paramdef>
<paramdef><type>float</type> <parameter>m</parameter></paramdef>
@@ -793,7 +793,7 @@ SELECT ST_Transform(ST_SetSRID( ST_Point( 3637510, 3014852 ), 2273), 4326)::geog
<refentry id="ST_PointZM">
<refnamediv>
<refname>ST_PointZM</refname>
+ <refpurpose>Creates a Point with X, Y, Z, M and SRID values.</refpurpose>
</refnamediv>
<refsynopsisdiv>
Summary of changes:
doc/reference_constructor.xml | 12 ++++++------
1 file changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
