[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-725-gb39f92142
Fri Apr 15 09:42:23 PDT 2022
the project "PostGIS".
       via  b39f921427795b27dc121d0de29950b9fac75c97 (commit)
       via  8d69d08b68c4f507cf14b69fa73c3a97ac2f6d4d (commit)
       via  0141554c6cc14c15a2edb48eb1474b0cb9bafd02 (commit)
       via  e3d36f810cf67315da6ca22ed735126eb0fd9d69 (commit)
      from  2eb420ed4f3defb28e496330dc03520f41b7680a (commit)
revisions in full, below.
commit b39f921427795b27dc121d0de29950b9fac75c97
Merge: 2eb420ed4 8d69d08b6
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Apr 15 11:53:46 2022 -0400
    Add SFCGAL ST_3DUnion aggregate (Sergei Shoulbakov)
    Closes #5132
    Closes https://github.com/postgis/postgis/pull/683
    Merge remote-tracking branch 'konturio/aggregate-3dunion'
diff --cc NEWS
index e043379ff,8093b473a..68a10949c
--- a/NEWS
+++ b/NEWS
@@@ -32,6 -30,6 +32,7 @@@ PostGIS 3.3.0de
    - postgis_sfcgal: sfcgal_full_version - reports BOOST and CGAL version
      (Loïc Bartoletti)
    - GH659, MARC21/XML, ST_GeomFromMARC21, ST_AsMARC21 (Jim Jones)
++  - #5132, GH683, sfcgal: ST_3DUnion aggregate function (Sergei Shoulbakov)
   * Bug Fix *
     - #5100, Support for PostgreSQL 15 (atoi removal) (Laurenz Albe)
commit 8d69d08b68c4f507cf14b69fa73c3a97ac2f6d4d
Author: sergei sh <sshoulbakov at kontur.io>
Date:   Fri Apr 15 14:57:18 2022 +0300
    ST_3DUnion tests
diff --git a/sfcgal/regress/regress_sfcgal.sql b/sfcgal/regress/regress_sfcgal.sql
index a337793b6..582ed2728 100644
--- a/sfcgal/regress/regress_sfcgal.sql
+++ b/sfcgal/regress/regress_sfcgal.sql
@@ -32,3 +32,14 @@ SELECT 'ST_StraightSkeleton', ST_AsText(ST_StraightSkeleton('POLYGON((1 1,2 1,2
 SELECT 'ST_ConstrainedDelaunayTriangles', ST_AsText(ST_ConstrainedDelaunayTriangles('GEOMETRYCOLLECTION(POINT(0 0), POLYGON((2 2, 2 -2, 4 0, 2 2)))'));
 SELECT 'postgis_sfcgal_noop', ST_NPoints(postgis_sfcgal_noop(ST_Buffer('POINT(0 0)', 5)));
 SELECT 'ST_3DConvexHull', ST_AsText(ST_3DConvexHull('MULTIPOINTZ(0 0 5, 1 5 3, 5 7 6, 9 5 3 , 5 7 5, 6 3 5)'));
+-- Result of ST_3DUnion is not deterministic and cannot be checked by
+-- simple string comparison
+SELECT 'ST_3DUnion', ABS(ST_Volume(ST_3DUnion(g1, g2)) - 40) < 1e-12 FROM (
+    SELECT ST_Extrude(ST_GeomFromText('POLYGON((-2 -2 -1, 2 -2 -1, 2 2 -1, -2 2 -1, -2 -2 -1))'), 0, 0, 2) AS g1,
+    ST_Extrude(ST_GeomFromText('POLYGON((-1 -1 -2, 1 -1 -2, 1 1 -2, -1 1 -2, -1 -1 -2))'), 0, 0, 4) AS g2
+) AS f;
+SELECT 'ST_3DUnion (aggregate)', ABS(ST_Volume(ST_3DUnion(g))) - 40 < 1e-12 FROM (
+    UNION
+    SELECT ST_Extrude(ST_GeomFromText('POLYGON((-1 -1 -2, 1 -1 -2, 1 1 -2, -1 1 -2, -1 -1 -2))'), 0, 0, 4) AS g
+) AS f;
diff --git a/sfcgal/regress/regress_sfcgal_expected b/sfcgal/regress/regress_sfcgal_expected
index 347a8e749..511be0b0f 100644
--- a/sfcgal/regress/regress_sfcgal_expected
+++ b/sfcgal/regress/regress_sfcgal_expected
@@ -12,3 +12,5 @@ ST_StraightSkeleton|MULTILINESTRING((1 1,1.5 1.5),(2 1,1.5 1.5),(2 2,1.5 1.5),(1
 ST_ConstrainedDelaunayTriangles|TIN(((4 0,2 2,2 -2,4 0)),((2 2,0 0,2 -2,2 2)))
 postgis_sfcgal_noop|33
 ST_3DConvexHull|POLYHEDRALSURFACE Z (((1 5 3,9 5 3,0 0 5,1 5 3)),((1 5 3,0 0 5,5 7 6,1 5 3)),((5 7 6,5 7 5,1 5 3,5 7 6)),((0 0 5,6 3 5,5 7 6,0 0 5)),((6 3 5,9 5 3,5 7 6,6 3 5)),((0 0 5,9 5 3,6 3 5,0 0 5)),((9 5 3,5 7 5,5 7 6,9 5 3)),((1 5 3,5 7 5,9 5 3,1 5 3)))
+ST_3DUnion|t
+ST_3DUnion (aggregate)|t
commit 0141554c6cc14c15a2edb48eb1474b0cb9bafd02
Date:   Wed Apr 13 11:47:15 2022 +0300
    aggregate ST_3DUnion: documentation fix
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index b4a26cb34..ba0d26626 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -815,7 +815,8 @@ FROM ( SELECT ST_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
 		<title>Description</title>
-		<para>Availability: 2.2.0, aggregate variant: 3.0.0</para>
+		<para>Availability: 2.2.0</para>
+		<para>Availability: 3.3.0 aggregate variant was added</para>
 		<para>&sfcgal_required;</para>
 		<para>&Z_support;</para>
 		<para>&P_support;</para>
commit e3d36f810cf67315da6ca22ed735126eb0fd9d69
Date:   Tue Apr 12 16:13:00 2022 +0300
index 00a14b4ae..b4a26cb34 100644
@@ -794,7 +794,7 @@ FROM ( SELECT ST_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
 	  <refnamediv>
 		<refname>ST_3DUnion</refname>
-		<refpurpose>Perform 3D union</refpurpose>
+		<refpurpose>Perform 3D union.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
@@ -804,6 +804,10 @@ FROM ( SELECT ST_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
 			<paramdef><type>geometry</type> <parameter>geom1</parameter></paramdef>
 			<paramdef><type>geometry</type> <parameter>geom2</parameter></paramdef>
 		  </funcprototype>
+		  <funcprototype>
+			<funcdef>geometry <function>ST_3DUnion</function></funcdef>
+			<paramdef><type>geometry set</type> <parameter>g1field</parameter></paramdef>
+		  </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -811,11 +815,20 @@ FROM ( SELECT ST_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
-		<para>Availability: 2.2.0</para>
+		<para>Availability: 2.2.0, aggregate variant: 3.0.0</para>
 		<para>&T_support;</para>
+        <para>
+            <emphasis role="bold">Aggregate variant:</emphasis>
+            returns a geometry that is the 3D union of a rowset of geometries.
+            The ST_3DUnion() function is an "aggregate"
+            function in the terminology of PostgreSQL. That means that it
+            operates on rows of data, in the same way the SUM() and AVG()
+            functions do and like most aggregates, it also ignores NULL geometries.
+        </para>
 	  </refsection>
 		  <refsection>
diff --git a/sfcgal/sfcgal.sql.in b/sfcgal/sfcgal.sql.in
index 3556e834c..57fe6ddd6 100644
--- a/sfcgal/sfcgal.sql.in
+++ b/sfcgal/sfcgal.sql.in
@@ -66,6 +66,13 @@ CREATE OR REPLACE FUNCTION ST_3DUnion(geom1 geometry, geom2 geometry)
        LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
        COST 100;
+-- Availability: 3.3.0
+CREATE AGGREGATE ST_3DUnion(geometry) (
+       sfunc = ST_3DUnion,
+       stype = geometry,
+       parallel = safe
 -- Availability: 2.1.0
 CREATE OR REPLACE FUNCTION ST_Tesselate(geometry)
        RETURNS geometry
Summary of changes:
 NEWS                                   |  1 +
 doc/reference_sfcgal.xml               | 16 +++++++++++++++-
 sfcgal/regress/regress_sfcgal.sql      | 11 +++++++++++
 sfcgal/regress/regress_sfcgal_expected |  2 ++
 sfcgal/sfcgal.sql.in                   |  7 +++++++
 5 files changed, 36 insertions(+), 1 deletion(-)
hooks/post-receive
