[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.5-39-g05123c4ab
git at osgeo.org
git at osgeo.org
Wed Apr 20 20:20:15 PDT 2022
the project "PostGIS".
The branch, stable-2.5 has been updated
via 05123c4ab7188ad03eeb3bf866be6587d1eb3f3f (commit)
from 7d17eb50ab1ed5f479ee1b7127783431b697911e (commit)
revisions in full, below.
commit 05123c4ab7188ad03eeb3bf866be6587d1eb3f3f
Author: Regina Obe <lr at pcorp.us>
Date: Wed Apr 20 23:02:41 2022 -0400
Prep for PostGIS 2.5.6
Update how to release docs to reflect new structure of hugo website
Note the 2.5 is not supported past PostgreSQL 12. Fix links.
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index f17e480cf..a0bc2106d 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -1,6 +1,6 @@
How to release
-Date: 2020-02-02
+Date: 2022-04-20
Versioning Scheme
@@ -102,18 +102,18 @@ Release procedure
- osgeo-discuss
- Update web sites
- PostGIS News
- - https://git.osgeo.org/gitea/postgis/postgis.net/src/master/_content/posts
+ - https://git.osgeo.org/gitea/postgis/postgis.net/src/branch/website/content/post
a) create a new Post for current year making sure the page name starts with mm-dd
- b) Update links on https://git.osgeo.org/gitea/postgis/postgis.net/src/master/_content/pages/source.html
+ b) Update dev and tag versions corresponding to this branch on https://git.osgeo.org/gitea/postgis/postgis.net/src/branch/website/config/_default/params.toml#L132
c) commit and wait 5 minutes to see changes on website
- PostGIS doc release versioned doc - http://postgis.net/documentation/
- - On postgis.net server, change /etc/nginx/sites-enabled/postgis.net (Versionless URL line )
- - nginx -t #to confirm you didn't breat the config
+ - (only needed for new branches) On postgis.net server, change /etc/nginx/sites-enabled/postgis.net (Versionless URL line )
+ - nginx -t #to confirm you didn't break the config
- service nginx reload
Verify the documentation is up to date (might need to change the apach config)
- Wikipedia
- Twitter
This should automatically happen as a result of posting to PostGIS website since Planet PostGIS and Planet PostgreSQL both autotweet.
-- Update Trac and make old Milestone as completed
+- Update Trac and mark old Milestone as completed
- Push the revision number forward (see Versioning Scheme)
- Remove the "dev" suffixed version from extensions/upgradeable_versions.mk
diff --git a/NEWS b/NEWS
index cbf7380ed..dcdcfd4e0 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
PostGIS 2.5.6
-2022/xx/xx
+2022/04/20
* Bug fixes *
diff --git a/Version.config b/Version.config
index b1e18525c..5955e973e 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=5
-POSTGIS_MICRO_VERSION=6dev
+POSTGIS_MICRO_VERSION=6
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/doc/installation.xml b/doc/installation.xml
index c7a36e757..4c887b80d 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -15,7 +15,7 @@ cd postgis-&last_release_version;
make
make install</programlisting>
<para>Once postgis is installed, it needs to be enabled in each individual database you want to use it in.</para>
- <note><para>The raster support is currently optional, but installed by default. For enabling using the PostgreSQL 9.1+ extensions model raster is required. Using the extension enable process is preferred and more user-friendly. To spatially enable your database:</para></note>
+ <note><para>The raster support is currently optional, but installed by default. For enabling using the extensions model raster is required. Using the extension enable process is preferred and more user-friendly. To spatially enable your database:</para></note>
<programlisting>psql -d yourdatabase -c "CREATE EXTENSION postgis;"
psql -d yourdatabase -c "CREATE EXTENSION postgis_topology;"
-- if you built with sfcgal support --
@@ -94,16 +94,16 @@ psql -d yourdatabase -f sfcgal_comments.sql
<itemizedlist>
<listitem>
<para>
- PostgreSQL &min_postgres_version; or higher. A complete installation
+ PostgreSQL &min_postgres_version; thru 12 are supported . A complete installation
of PostgreSQL (including server headers) is required. PostgreSQL
is available from
- <ulink url="http://www.postgresql.org">
- http://www.postgresql.org
+ <ulink url="https://www.postgresql.org">
+ https://www.postgresql.org
</ulink>
</para>
<para>For a full PostgreSQL / PostGIS support matrix and PostGIS/GEOS support matrix refer to
- <ulink url="http://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS">http://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS</ulink>
+ <ulink url="https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS">https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS</ulink>
</para>
</listitem>
@@ -2483,33 +2483,33 @@ ALTER EXTENSION postgis_topology UPDATE TO "&last_release_version;next";</progra
<programlisting>ALTER TABLE spatial_ref_sys ADD CONSTRAINT spatial_ref_sys_srid_check check (srid > 0 AND srid < 999000 );</programlisting>
<programlisting>ALTER TABLE spatial_ref_sys ADD PRIMARY KEY(srid));</programlisting>
If you are upgrading an old database containing french <ulink url="https://en.wikipedia.org/wiki/Institut_g%C3%A9ographique_national">
IGN
- </ulink> cartography, you will have probably SRIDs out
+ </ulink> cartography, you will have probably SRIDs out
of range and you will see, when importing your database, issues like this :
<programlisting> WARNING: SRID 310642222 converted to 999175 (in reserved zone)</programlisting>
- In this case, you can try following steps : first throw
- out completely the IGN from the sql which is resulting
+ In this case, you can try following steps : first throw
+ out completely the IGN from the sql which is resulting
from postgis_restore.pl. So, after having run :
<programlisting>perl utils/postgis_restore.pl "/somepath/olddb.backup" > oldbb.sql</programlisting>
run this command :
<programlisting>grep -v IGNF olddb.sql > olddb-without-IGN.sql</programlisting>
- Create then your newdb, activate the required Postgis extensions,
+ Create then your newdb, activate the required Postgis extensions,
and insert properly the french system IGN with :
<ulink url="https://raw.githubusercontent.com/Remi-C/IGN_spatial_ref_for_PostGIS/master/Put_IGN_SRS_into_Postgis.sql">
this script
</ulink>
After these operations, import your data :
<programlisting>psql -h localhost -p 5432 -U postgres -d newdb -f olddb-without-IGN.sql 2> errors.txt</programlisting>
</para>
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 2efb86930..e9be19d15 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -4,7 +4,7 @@
<subtitle>Release Notes</subtitle>
<sect1>
<title>PostGIS 2.5.6</title>
- <para>Release Date: 2022/02/03</para>
+ <para>Release Date: 2022/04/20</para>
<simplesect>
<title>Bug fixes</title>
<para>4968, Update autogen.sh to handle autoconf 2.71 issues</para>
@@ -22,6 +22,7 @@
use native GEOS makevalid, buildarea, clipbybox (Regina Obe)</para>
<para>4457, Stop trying to createlang in regress
plpgsql is always installed (Regina Obe)</para>
+ <para>4980, Support pkg-config for pcre detection (Regina Obe)</para>
</simplesect>
</sect1>
Summary of changes:
HOWTO_RELEASE | 12 ++++++------
NEWS | 2 +-
Version.config | 2 +-
doc/installation.xml | 36 ++++++++++++++++++------------------
doc/release_notes.xml | 3 ++-
5 files changed, 28 insertions(+), 27 deletions(-)
hooks/post-receive
