[postgis-tickets] [PostGIS] #5078: 2.5.6dev--3.3.0dev upgrade fails: cannot change name of input parameter "param_geom"
PostGIS trac at osgeo.org
Tue Feb 1 03:51:03 PST 2022
"param_geom"
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 NOTE: the problem occurs ONLY when using a new enough GEOS.
 For example Dronie does not fail the upgrade, while using GEOS-3.6:
 https://dronie.osgeo.org/postgis/postgis/2713/1/4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5078#comment:4>
