[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-458-gf72272c7e
Wed Feb 2 10:31:59 PST 2022
the project "PostGIS".
       via  f72272c7e0cac42fe28aad1bd4abb2c91ee7363d (commit)
      from  972fce5a06445e8422e07f34ad16e1c01d387005 (commit)
revisions in full, below.
commit f72272c7e0cac42fe28aad1bd4abb2c91ee7363d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Feb 2 10:31:55 2022 -0800
    Match doc param names to SQL param names
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index bc84cf142..01a87f85c 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -619,9 +619,9 @@ POINT(0.5 1)
         <funcsynopsis>
          <funcprototype>
             <funcdef>geometry <function>ST_ConcaveHull</function></funcdef>
-            <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
-            <paramdef><type>float </type> <parameter>target_percent</parameter></paramdef>
-            <paramdef choice="opt"><type>boolean </type> <parameter>allow_holes = false</parameter></paramdef>
+            <paramdef><type>geometry </type> <parameter>param_geom</parameter></paramdef>
+            <paramdef><type>float </type> <parameter>param_pctconvex</parameter></paramdef>
+            <paramdef choice="opt"><type>boolean </type> <parameter>param_allow_holes = false</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
       </refsynopsisdiv>
@@ -632,7 +632,7 @@ POINT(0.5 1)
         <para>A concave hull of a geometry is a possibly concave
         geometry that encloses the vertices of the input geometry.
         In the general case the concave hull is a Polygon.
-        The polygon will not contain holes unless the optional <varname>allow_holes</varname>
+        The polygon will not contain holes unless the optional <varname>param_allow_holes</varname>
         argument is specified as true.
         The concave hull of two or more collinear points is a two-point LineString.
         The concave hull of one or more identical points is a Point.
@@ -646,7 +646,7 @@ POINT(0.5 1)
         Like the convex hull, the vertices of a concave hull are a subset of the input points,
         and all other input points are contained within it.</para>
-        <para>The <varname>target_percent</varname> controls the concaveness of the computed hull.
+        <para>The <varname>param_pctconvex</varname> controls the concaveness of the computed hull.
         A value of 1 produces the convex hull.
         A value of 0 produces a hull of maximum concaveness (but still a single polygon).
         Values between 1 and 0 produce hulls of increasing concaveness.
Summary of changes:
 doc/reference_processing.xml | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
