[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-460-g8549294e8
Wed Feb 2 11:14:13 PST 2022
the project "PostGIS".
       via  8549294e8c8b289e24a141f99e1859f640937a7d (commit)
      from  6f335e8117bcbc43daa9e0536c0703e3926f8acd (commit)
revisions in full, below.
commit 8549294e8c8b289e24a141f99e1859f640937a7d
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Feb 2 11:14:08 2022 -0800
    Improve doc ST_ClusterKmeans examples
diff --git a/doc/html/image_src/Makefile.in b/doc/html/image_src/Makefile.in
index 99d729eb4..fb4bf5cb2 100644
--- a/doc/html/image_src/Makefile.in
+++ b/doc/html/image_src/Makefile.in
@@ -47,7 +47,6 @@ IMAGES= \
 	../images/st_buildarea01.png \
 	../images/st_closestpoint01.png \
 	../images/st_closestpoint02.png \
-	../images/st_clusterkmeans01.png \
 	../images/st_clusterkmeans02.png \
 	../images/st_centroid01.png \
 	../images/st_centroid02.png \
diff --git a/doc/html/image_src/st_clusterkmeans01.wkt b/doc/html/image_src/st_clusterkmeans01.wkt
deleted file mode 100644
index c9e1e7abf..000000000
--- a/doc/html/image_src/st_clusterkmeans01.wkt
+++ /dev/null
@@ -1,7 +0,0 @@
-ArgA;POLYGON((0 60,0 112.262823104858,69.9840240478516 112.262823104858,69.9840240478516 35.2699669619124,32.8889744907202 60,0 60))
-ArgA;POLYGON((69.9840240478516 35.2699669619124,69.9840240478516 73.3964014053345,127.637811131417 73.3964014053345,125.713274243959 71.1560330280473,119.721714690708 66.4118010173891,112.937223991122 62.8936752097563,105.60746371632 60.7300815406388,98 60,88.0740170061865 60,71.0940039245046 34.5299803774771,69.9840240478516 35.2699669619124))
-ArgA;POLYGON((69.9840240478516 73.3964014053345,69.9840240478516 112.262823104858,138.522500134424 112.262823104858,137.968038348872 98.4012784660451,136.934484771969 90.829073354271,134.479663763751 83.5916444552268,130.693186299402 76.9531874309565,127.637811131417 73.3964014053345,69.9840240478516 73.3964014053345))
-ArgA;POLYGON((0 112.262823104858,0 140,45.2593163271468 140,66.7179882264863 172.188007849009,69.9840240478516 176.163370657516,69.9840240478516 112.262823104858,0 112.262823104858))
-ArgA;POLYGON((69.9840240478516 112.262823104858,69.9840240478516 151.129244804382,139.80478252734 151.129244804382,139.968038348872 148.401278466045,138.522500134424 112.262823104858,69.9840240478516 112.262823104858))
-ArgA;POLYGON((69.9840240478516 151.129244804382,69.9840240478516 176.163370657516,71.7754637625827 178.343880365658,77.9526212087179 183.375336529146,85.0044095429824 187.08277587837,92.6510806850222 189.319122382143,100.589287246674 189.99565902121,104.976036071777 189.491234771783,104.976036071777 151.129244804382,69.9840240478516 151.129244804382))
-ArgA;POLYGON((104.976036071777 151.129244804382,104.976036071777 189.491234771783,108.50411647931 189.085547238159,116.081583025004 186.624891636835,123.021084877624 182.711307694087,129.047328419456 177.500049303452,133.921249461013 171.19784977312,137.44949704073 164.054720608975,139.492103757341 156.354033429203,139.80478252734 151.129244804382,104.976036071777 151.129244804382))
diff --git a/doc/reference_cluster.xml b/doc/reference_cluster.xml
index ce2508a92..860a3f8ec 100644
--- a/doc/reference_cluster.xml
+++ b/doc/reference_cluster.xml
@@ -248,7 +248,7 @@ GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
     <refsection>
       <title>Examples</title>
-		<para>Generate dummy set of parcels for examples</para>
+		<para>Generate dummy set of parcels for examples:</para>
 		<programlisting>CREATE TABLE parcels AS
 SELECT lpad((row_number() over())::text,3,'0') As parcel_id, geom,
 ('{residential, commercial}'::text[])[1 + mod(row_number()OVER(),2)] As type
@@ -257,31 +257,17 @@ FROM
     40, 'endcap=square'),12) As geom;
 </programlisting>
-	<informaltable>
-			  <tgroup cols="1">
-				<tbody>
-				  <row>
-					<entry>
-						<para><informalfigure>
-						<mediaobject>
-						  <imageobject>
-							<imagedata fileref="images/st_clusterkmeans01.png" />
-						  </imageobject>
-						  <caption><para>Original Parcels</para></caption>
-						</mediaobject>
-						</informalfigure>
-						</para>
-					</entry>
-					<entry><para><informalfigure>
-						<mediaobject>
-						  <imageobject>
-							<imagedata fileref="images/st_clusterkmeans02.png" />
-						  </imageobject>
-						  <caption><para>Parcels color-coded by cluster number (cid)</para></caption>
-						</mediaobject>
-					  </informalfigure>
-						<programlisting>SELECT ST_ClusterKMeans(geom, 5) OVER() AS cid, parcel_id, geom
-FROM parcels;</programlisting>
+        <para><informalfigure>
+            <mediaobject>
+                <imageobject>
+                <imagedata fileref="images/st_clusterkmeans02.png" />
+                </imageobject>
+                <caption><para>Parcels color-coded by cluster number (cid)</para></caption>
+            </mediaobject>
+            </informalfigure>
+<programlisting>
+SELECT ST_ClusterKMeans(geom, 3) OVER() AS cid, parcel_id, geom
+    FROM parcels;</programlisting>
 <screen> cid | parcel_id |   geom
    0 | 001       | 0103000000...
@@ -291,15 +277,13 @@ FROM parcels;</programlisting>
    1 | 005       | 0103000000...
    2 | 006       | 0103000000...
    2 | 007       | 0103000000...
-(7 rows)</screen>
-					</para></entry>
-				  </row>
-			</tbody>
-			</tgroup>
-		</informaltable>
-<para>Partitioning parcel clusters by type:</para>
-		    <programlisting>SELECT ST_ClusterKMeans(geom, 3) over (PARTITION BY type) AS cid, parcel_id, type
+</screen>
+        </para>
+        <para>Partitioning parcel clusters by type:</para>
+<programlisting>
+SELECT ST_ClusterKMeans(geom, 3) over (PARTITION BY type) AS cid, parcel_id, type
 <screen> cid | parcel_id |    type
    1 | 005       | commercial
@@ -309,12 +293,14 @@ FROM parcels;</programlisting>
    1 | 004       | residential
    0 | 002       | residential
    2 | 006       | residential
-(7 rows)</screen>
-<para>Clustering preaggregated planetary scale data like population dataset may require using 3D clusering and weighting.
-Let's try to idenify 20-ish meta-regions based on <ulink url="https://data.humdata.org/dataset/kontur-population-dataset">Kontur Population</ulink> that will not span more than 3000 km from their center:</para>
-		    <programlisting>create table kontur_population_3000km_clusters as
+</screen>
+<para>Example: Clustering a preaggregated planetary-scale data population dataset
+using 3D clusering and weighting.
+Identify at least 20 regions based on
+<ulink url="https://data.humdata.org/dataset/kontur-population-dataset">Kontur Population Data</ulink>
+that do not span more than 3000 km from their center:</para>
+<programlisting>create table kontur_population_3000km_clusters as
 select
     geom,
     ST_ClusterKMeans(
@@ -333,7 +319,11 @@ from
         <imageobject>
         <imagedata fileref="images/st_clusterkmeans03.png" />
         </imageobject>
-        <caption><para>World population clustered to above specs: 46 resulting clusters. Greenland is one cluster, there are island clusters that span across antimeridian, clusters are centered at well-populated regions (New York, Moscow), and edges follow Earth's curvature.</para></caption>
+        <caption><para>World population clustered to above specs produces 46 clusters.
+        Clusters are centered at well-populated regions (New York, Moscow).
+        Greenland is one cluster.
+        There are island clusters that span across the antimeridian.
+        Cluster edges follow Earth's curvature.</para></caption>
     </mediaobject>
     </informalfigure>
     </para>
Summary of changes:
 doc/html/image_src/Makefile.in            |  1 -
 doc/html/image_src/st_clusterkmeans01.wkt |  7 ---
 doc/reference_cluster.xml                 | 74 +++++++++++++------------------
 3 files changed, 32 insertions(+), 50 deletions(-)
 delete mode 100644 doc/html/image_src/st_clusterkmeans01.wkt
hooks/post-receive
