[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-464-gef7cf315d
git at osgeo.org
git at osgeo.org
Wed Feb 2 12:49:07 PST 2022
the project "PostGIS".
via ef7cf315d1819536dbb374e535a264dd2b25f232 (commit)
from 169d452431cc11553a8db25025fe89b1d41aabb3 (commit)
revisions in full, below.
commit ef7cf315d1819536dbb374e535a264dd2b25f232
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Feb 2 12:49:02 2022 -0800
Improve doc for ST_Subdivide
diff --git a/doc/reference_overlay.xml b/doc/reference_overlay.xml
index 93baa1d97..e3c944c28 100644
--- a/doc/reference_overlay.xml
+++ b/doc/reference_overlay.xml
@@ -620,7 +620,8 @@ GEOMETRYCOLLECTION(
<title>Description</title>
<para>
- A set-returning function that divides geometry into parts using rectilinear lines,
+ Returns a set of geometries that are the result of dividing <varname>geom</varname>
+ into parts using rectilinear lines,
with each part containing no more than <code>max_vertices</code>.
</para>
<para>
@@ -629,11 +630,18 @@ GEOMETRYCOLLECTION(
</para>
<para>
Point-in-polygon and other spatial operations are normally faster for indexed subdivided datasets.
- Since the bounding boxes for parts usually cover a smaller area than original geometry bbox,
- the index queries are more selective and produce fewer "hit" cases.
+ Since the bounding boxes for the parts usually cover a smaller area than the original geometry bbox,
+ index queries produce fewer "hit" cases.
The "hit" cases are faster because the spatial operations
executed by the index recheck process fewer points.
</para>
+ <note><para>
+ This is a <ulink url="https://www.postgresql.org/docs/current/queries-table-expressions.html#QUERIES-TABLEFUNCTIONS">set-returning function</ulink>
+ (SRF) that return a set of rows containing single geometry values.
+ It can be used in a SELECT list or a FROM clause
+ to produce a result set with one record for each result geometry.
+ </para></note>
<para>Performed by the GEOS module.</para>
<para>Availability: 2.2.0</para>
<para>Enhanced: 2.5.0 reuses existing points on polygon split, vertex count is lowered from 8 to 5.</para>
@@ -720,12 +728,15 @@ INSERT INTO polygons_table (fid, column1, column2, column3, geom)
Create a new table containing subdivided geometries,
retaining the key of the original geometry so that the new table
can be joined to the source table.
+ Since ST_Subdivide is a set-returning (table) function
+ that returns a set of single-value rows,
+ this syntax automatically produces a table with one row for each result part.
</para>
-<programlisting>-- Create a new subdivided table suitable for joining to the original
+<programlisting>
CREATE TABLE subdivided_geoms AS
-SELECT pkey, ST_Subdivide(geom) AS geom
-FROM original_geoms;
+ SELECT pkey, ST_Subdivide(geom) AS geom
+ FROM original_geoms;
</programlisting>
</refsection>
Summary of changes:
doc/reference_overlay.xml | 23 +++++++++++++++++------
1 file changed, 17 insertions(+), 6 deletions(-)
hooks/post-receive
