[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-469-gc6241f8c0
git at osgeo.org
git at osgeo.org
Wed Feb 2 16:20:25 PST 2022
the project "PostGIS".
via c6241f8c0ab54b4018d4d285a2c44b24608af891 (commit)
from 9ee87862195400f8483127cdd6ed7bac8322e247 (commit)
revisions in full, below.
commit c6241f8c0ab54b4018d4d285a2c44b24608af891
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Feb 2 16:20:21 2022 -0800
Add doc image generator verbose flag
diff --git a/doc/html/image_src/generator.c b/doc/html/image_src/generator.c
index 6e8d6ebf1..9679809d8 100644
--- a/doc/html/image_src/generator.c
+++ b/doc/html/image_src/generator.c
@@ -4,6 +4,7 @@
* http://postgis.net
* Copyright (C) 2022 Sandro Santilli <strk at kbt.io>
+ * Copyright (C) 2022 Martin Davis
* Copyright 2008 Kevin Neufeld
* This is free software; you can redistribute and/or modify it under
@@ -12,8 +13,9 @@
* This program will generate a .png image for every .wkt file specified
* in this directory's Makefile. Every .wkt file may contain several
* entries of geometries represented as WKT strings. Every line in
- * a wkt file is stylized using a predetermined style (line thinkness,
- * fill color, etc) currently hard coded in this programs main function.
+ * a wkt file is stylized using a predetermined style (line thickness,
+ * fill color, etc).
+ * The styles are specified in the adjacent styles.conf file.
* In order to generate a png file, ImageMagicK must be installed in the
* user's path as system calls are invoked to "convert". In this manner,
@@ -28,6 +30,14 @@
* rendered outside of the generated image's extents, or may be rendered too
* small to be recognizable as anything other than a single point.
+ * Usage:
+ * generator [-v] <source_wktfile> [<output_pngfile>]
+ * -v - show generated Imagemagick commands
+ * If <output_pngfile> is omitted the output image PNG file has the
+ * same name as the source file
#include <stdio.h>
@@ -35,6 +45,7 @@
#include <string.h>
#include <ctype.h>
#include <sys/wait.h> /* for WEXITSTATUS */
+#include <stdbool.h>
#include "liblwgeom_internal.h"
#include "lwgeom_log.h"
@@ -44,6 +55,8 @@
#define MAX_DOUBLE_PRECISION 15
#define MAX_DIGS_DOUBLE (SHOW_DIGS_DOUBLE + 2) /* +2 for dot and sign */
+bool optionVerbose = false;
// Some global styling variables
char *imageSize = "200x200";
@@ -356,10 +369,22 @@ getStyleName(char **styleName, char* line)
+int parseOptions(int argc, const char* argv[] )
+ if (argc <= 1) return 1;
+ int argPos = 1;
+ while (strncmp(argv[argPos], "-", 1) == 0) {
+ if (strncmp(argv[argPos], "-v", 2) == 0) {
+ optionVerbose = true;
+ argPos++;
+ return argPos;
- * Main Application. Currently, drawing styles are hardcoded in this method.
- * Future work may entail reading the styles from a .properties file.
+ * Main Application.
int main( int argc, const char* argv[] )
@@ -374,13 +399,14 @@ int main( int argc, const char* argv[] )
char *ptr;
const char *stylefilename = "styles.conf";
- if ( argc < 2 || strlen(argv[1]) < 3)
+ int filePos = parseOptions(argc, argv);
+ if ( filePos >= argc || strlen(argv[filePos]) < 3)
- lwerror("Usage: %s <source_wktfile> [<output_pngfile>]", argv[0]);
+ lwerror("Usage: %s [-v] <source_wktfile> [<output_pngfile>]", argv[0]);
return -1;
- image_src = argv[1];
+ image_src = argv[filePos];
if ( (pfile = fopen(image_src, "r")) == NULL)
@@ -406,9 +432,9 @@ int main( int argc, const char* argv[] )
getStyles(stylefile_path, &styles);
free(stylefile_path);
- if ( argc > 2 )
+ if ( argc - filePos >= 2 )
- filename = strdup(argv[2]);
+ filename = strdup(argv[filePos + 1]);
else
@@ -454,7 +480,9 @@ int main( int argc, const char* argv[] )
lwgeom_free( lwgeom );
LWDEBUGF( 4, "%s", output );
- //puts(output);
+ if (optionVerbose) {
+ puts(output);
checked_system(output);
//-- (MD) disable highlighting since it doesn't work well with opacity
diff --git a/doc/html/image_src/styles.c b/doc/html/image_src/styles.c
index 587afb1ed..0a6fd1acf 100644
--- a/doc/html/image_src/styles.c
+++ b/doc/html/image_src/styles.c
@@ -2,13 +2,13 @@
* PostGIS - Spatial Types for PostgreSQL
* the terms of the GNU General Public Licence. See the COPYING file.
- * TODO: fix segfault bug caused by a referenced style that doesn't exist in
- * the .conf file
#include <stdio.h>
Summary of changes:
doc/html/image_src/generator.c | 48 +++++++++++++++++++++++++++++++++---------
doc/html/image_src/styles.c | 4 ++--
2 files changed, 40 insertions(+), 12 deletions(-)
hooks/post-receive
