[postgis-tickets] [SCM] PostGIS branch spatial-ref-sys-view updated. 3.2.0-464-g660283b36
Thu Feb 3 05:33:53 PST 2022
the project "PostGIS".
The branch, spatial-ref-sys-view has been updated
       via  660283b3631719fbd0db3076415db7f2d3b55d9f (commit)
      from  a363cfcc1d7e3664547790e7d0f907b5f33bf087 (commit)
revisions in full, below.
commit 660283b3631719fbd0db3076415db7f2d3b55d9f
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Feb 3 14:32:52 2022 +0100
    Update tests to not edit spatial_ref_sys directly
    Unless the test is *specifically* testing backward compatibility
diff --git a/raster/test/regress/rt_asraster.sql b/raster/test/regress/rt_asraster.sql
index 88c58f091..38c1a8123 100644
--- a/raster/test/regress/rt_asraster.sql
+++ b/raster/test/regress/rt_asraster.sql
@@ -40,15 +40,15 @@ CREATE OR REPLACE FUNCTION make_test_raster()
 SELECT make_test_raster();
 DROP FUNCTION make_test_raster();
-DELETE FROM "spatial_ref_sys" WHERE srid = 992163;
-DELETE FROM "spatial_ref_sys" WHERE srid = 993309;
-DELETE FROM "spatial_ref_sys" WHERE srid = 993310;
-DELETE FROM "spatial_ref_sys" WHERE srid = 994269;
+DELETE FROM "spatial_ref_sys_user" WHERE srid = 992163;
+DELETE FROM "spatial_ref_sys_user" WHERE srid = 993309;
+DELETE FROM "spatial_ref_sys_user" WHERE srid = 993310;
+DELETE FROM "spatial_ref_sys_user" WHERE srid = 994269;
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (992163,'EPSG',2163,'PROJCS["unnamed",GEOGCS["unnamed ellipse",DATUM["unknown",SPHEROID["unnamed",6370997,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Lambert_Azimuthal_Equal_Area"],PARAMETER["latitude_of_center",45],PARAMETER["longitude_of_center",-100],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1],AUTHORITY["EPSG","2163"]]','+proj=laea +lat_0=45 +lon_0=-100 +x_0=0 +y_0=0 +a=6370997 +b=6370997 +units=m +no_defs ');
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (993309,'EPSG',3309,'PROJCS["NAD27 / California Albers",GEOGCS["NAD27",DATUM["North_American_Datum_1927",SPHEROID["Clarke 1866",6378206.4,294.9786982139006,AUTHORITY["EPSG","7008"]],AUTHORITY["EPSG","6267"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4267"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["standard_parallel_1",34],PARAMETER["standard_parallel_2",40.5],PARAMETER["latitude_of_center",0],PARAMETER["longitude_of_center",-120],PARAMETER["false_easting",0],PARAMETER["false_northing",-4000000],AUTHORITY["EPSG","3309"],AXIS["X",EAST],AXIS["Y",NORTH]]','+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=clrk66 +datum=NAD27 +units=m +no_defs ');
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (993310,'EPSG',3310,'PROJCS["NAD83 / California Albers",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["standard_parallel_1",34],PARAMETER["standard_parallel_2",40.5],PARAMETER["latitude_of_center",0],PARAMETER["longitude_of_center",-120],PARAMETER["false_easting",0],PARAMETER["false_northing",-4000000],AUTHORITY["EPSG","3310"],AXIS["X",EAST],AXIS["Y",NORTH]]','+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs ');
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (994269,'EPSG',4269,'GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]]','+proj=longlat +ellps=GRS80 +datum=NAD83 +no_defs ');
+INSERT INTO "spatial_ref_sys_user" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (992163,'EPSG',2163,'PROJCS["unnamed",GEOGCS["unnamed ellipse",DATUM["unknown",SPHEROID["unnamed",6370997,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Lambert_Azimuthal_Equal_Area"],PARAMETER["latitude_of_center",45],PARAMETER["longitude_of_center",-100],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1],AUTHORITY["EPSG","2163"]]','+proj=laea +lat_0=45 +lon_0=-100 +x_0=0 +y_0=0 +a=6370997 +b=6370997 +units=m +no_defs ');
+INSERT INTO "spatial_ref_sys_user" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (993309,'EPSG',3309,'PROJCS["NAD27 / California Albers",GEOGCS["NAD27",DATUM["North_American_Datum_1927",SPHEROID["Clarke 1866",6378206.4,294.9786982139006,AUTHORITY["EPSG","7008"]],AUTHORITY["EPSG","6267"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4267"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["standard_parallel_1",34],PARAMETER["standard_parallel_2",40.5],PARAMETER["latitude_of_center",0],PARAMETER["longitude_of_center",-120],PARAMETER["false_easting",0],PARAMETER["false_northing",-4000000],AUTHORITY["EPSG","3309"],AXIS["X",EAST],AXIS["Y",NORTH]]','+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=clrk66 +datum=NAD27 +units=m +no_defs ');
+INSERT INTO "spatial_ref_sys_user" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (993310,'EPSG',3310,'PROJCS["NAD83 / California Albers",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["standard_parallel_1",34],PARAMETER["standard_parallel_2",40.5],PARAMETER["latitude_of_center",0],PARAMETER["longitude_of_center",-120],PARAMETER["false_easting",0],PARAMETER["false_northing",-4000000],AUTHORITY["EPSG","3310"],AXIS["X",EAST],AXIS["Y",NORTH]]','+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs ');
+INSERT INTO "spatial_ref_sys_user" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (994269,'EPSG',4269,'GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]]','+proj=longlat +ellps=GRS80 +datum=NAD83 +no_defs ');
 INSERT INTO raster_asraster_geom VALUES (
 ST_GeomFromText('MULTIPOLYGON(((-172210.499109288 114987.660953018,-175453.086381862 29201.5994536821,-151944.038528546 28257.4637483698,-151755.193144738 64618.6592845297,-129779.244489461 63766.2346307114,-132720.730482521 29365.7452160339,-110176.183408147 28076.2457866343,-113336.283431208 112064.985603184,-135659.619600536 112878.300914729,-134301.95687566 79576.8821948012,-153850.618867315 80395.4252778995,-151346.215838074 112678.410158427,-172210.499109288 114987.660953018)),((-86135.5150847774 77502.7616508612,-87105.1850870571 30678.0039829779,-69362.3449961895 29072.3373203999,-70858.5814585458 78310.0439012805,-86135.5150847774 77502.7616508612)),((-86888.5102830273 96546.8546876945,-86065.7795470885 84169.9977753228,-70801.2145468401 84976.5822106288,-72118.6159803197 97829.7405064492,-86888.5102830273 96546.8546876945)),((-50136.8809020698 111909.445130098,-48631.3614059008 44728.8885465469,-36172.0195739627 45621.806341459,-39695.018962698 109480.225649309,-50136.8809
 020698 111909.445130098)),((-47695.3501850868 40894.9976787795,-47761.6362577873 29399.0052930373,-34799.4262271112 30293.0638067261,-35717.8219710071 39877.2161100041,-47695.3501850868 40894.9976787795)))', 993310)
@@ -499,10 +499,10 @@ FROM (
 	ORDER BY d.rid
 ) foo;
 DROP TABLE raster_asraster_geom;
 DROP TABLE raster_asraster_rast;
diff --git a/raster/test/regress/rt_gdalwarp.sql b/raster/test/regress/rt_gdalwarp.sql
index 1950b3ae3..274908ae6 100644
--- a/raster/test/regress/rt_gdalwarp.sql
+++ b/raster/test/regress/rt_gdalwarp.sql
@@ -35,18 +35,18 @@ CREATE OR REPLACE FUNCTION make_test_raster()
-DELETE FROM "spatial_ref_sys" WHERE srid = 984269;
-DELETE FROM "spatial_ref_sys" WHERE srid = 974269;
+DELETE FROM "spatial_ref_sys_user" WHERE srid = 984269;
+DELETE FROM "spatial_ref_sys_user" WHERE srid = 974269;
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (992163,'EPSG',2163,'PROJCS["unnamed",GEOGCS["unnamed ellipse",DATUM["unknown",SPHEROID["unnamed",6370997,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Lambert_Azimuthal_Equal_Area"],PARAMETER["latitude_of_center",45],PARAMETER["longitude_of_center",-100],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1],AUTHORITY["EPSG","2163"]]','+proj=laea +lat_0=45 +lon_0=-100 +x_0=0 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs ');
+INSERT INTO "spatial_ref_sys_user" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (992163,'EPSG',2163,'PROJCS["unnamed",GEOGCS["unnamed ellipse",DATUM["unknown",SPHEROID["unnamed",6370997,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Lambert_Azimuthal_Equal_Area"],PARAMETER["latitude_of_center",45],PARAMETER["longitude_of_center",-100],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1],AUTHORITY["EPSG","2163"]]','+proj=laea +lat_0=45 +lon_0=-100 +x_0=0 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs ');
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","srtext","proj4text") VALUES (984269,'EPSG','GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]]','+proj=longlat +ellps=GRS80 +datum=NAD83 +no_defs ');
-INSERT INTO "spatial_ref_sys" ("srid","srtext") VALUES (974269,'GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]]');
+INSERT INTO "spatial_ref_sys_user" ("srid","auth_name","srtext","proj4text") VALUES (984269,'EPSG','GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]]','+proj=longlat +ellps=GRS80 +datum=NAD83 +no_defs ');
+INSERT INTO "spatial_ref_sys_user" ("srid","srtext") VALUES (974269,'GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]]');
 -- _st_gdalwarp
 INSERT INTO raster_gdalwarp_dst (rid, rast) VALUES (
@@ -797,12 +797,8 @@ SELECT
 	ST_SameAlignment(aligned) AS aligned
 FROM baz;
+DELETE FROM "spatial_ref_sys_user" WHERE srid IN (
+992163, 993310, 993310, 994269, 984269, 974269 );
 -- ST_Resize()
 WITH foo AS(
diff --git a/regress/core/in_gml.sql b/regress/core/in_gml.sql
index 534e79e7f..e2ad7dcf7 100644
--- a/regress/core/in_gml.sql
+++ b/regress/core/in_gml.sql
@@ -634,14 +634,14 @@ SELECT 'srs_15', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName=""><gml:pos>1 2</g
 SELECT 'srs_16', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="EPSG:-1"><gml:pos>1 2</gml:pos></gml:Point>'));
 -- Ensure upcoming tests have the SRIDs they need
-INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (1, 'EPSG', 4978, 'GEOCCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Geocentric X",OTHER],AXIS["Geocentric Y",OTHER],AXIS["Geocentric Z",NORTH],AUTHORITY["EPSG","4978"]]', '+proj=geocent +datum=WGS84 +units=m +no_defs ');
-INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (2, 'EPSG', 4979, 'GEOGCRS["WGS 84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,3],AXIS["geodetic latitude (Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["geodetic longitude (Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],AXIS["ellipsoidal height (h)",up,ORDER[3],LENGTHUNIT["metre",1]],USAGE[SCOPE["unknown"],AREA["World (by country)"],BBOX[-90,-180,90,180]],ID["EPSG",4979]]', '+proj=longlat +datum=WGS84 +no_defs');
-INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (3, 'EPSG', 4985, 'BOUNDCRS[SOURCECRS[GEOGCRS["WGS 72",DATUM["World Geodetic System 1972",ELLIPSOID["WGS 72",6378135,298.26,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,3],AXIS["geodetic latitude (Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["geodetic longitude (Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],AXIS["ellipsoidal height (h)",up,ORDER[3],LENGTHUNIT["metre",1]],USAGE[SCOPE["unknown"],AREA["World"],BBOX[-90,-180,90,180]],ID["EPSG",4985]]],TARGETCRS[GEOGCRS["WGS 84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,2],AXIS["latitude",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["longitude",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],ID["EPSG",4326]]],ABRIDGE
 DTRANSFORMATION["WGS 72 to WGS 84 (1)",VERSION["DMA1"],METHOD["Position Vector transformation (geog2D domain)",ID["EPSG",9606]],PARAMETER["X-axis translation",0,ID["EPSG",8605]],PARAMETER["Y-axis translation",0,ID["EPSG",8606]],PARAMETER["Z-axis translation",4.5,ID["EPSG",8607]],PARAMETER["X-axis rotation",0,ID["EPSG",8608]],PARAMETER["Y-axis rotation",0,ID["EPSG",8609]],PARAMETER["Z-axis rotation",0.554,ID["EPSG",8610]],PARAMETER["Scale difference",1.0000002263,ID["EPSG",8611]],USAGE[SCOPE["unknown"],AREA["World"],BBOX[-90,-180,90,180]],ID["DERIVED_FROM(EPSG)",1237]]]', '+proj=longlat +ellps=WGS72 +towgs84=0,0,4.5,0,0,0.554,0.2263 +no_defs');
-INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (4, 'EPSG', 8360, 'COMPD_CS["ETRS89 + Baltic 1957 height",GEOGCS["ETRS89",DATUM["European_Terrestrial_Reference_System_1989",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6258"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AXIS["Latitude",NORTH],AXIS["Longitude",EAST],AUTHORITY["EPSG","4258"]],VERT_CS["Baltic 1957 height",VERT_DATUM["Baltic 1957",2005,AUTHORITY["EPSG","1202"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Gravity-related height",UP],AUTHORITY["EPSG","8357"]],AUTHORITY["EPSG","8360"]]', '+proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +vunits=m +no_defs');
-INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (5, 'EPSG', 8433, 'PROJCS["Macao 1920 / Macao Grid",GEOGCS["Macao 1920",DATUM["Macao_1920",SPHEROID["International 1924",6378388,297,AUTHORITY["EPSG","7022"]],AUTHORITY["EPSG","1207"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","8428"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",22.2123972222222],PARAMETER["central_meridian",113.536469444444],PARAMETER["scale_factor",1],PARAMETER["false_easting",20000],PARAMETER["false_northing",20000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Northing",NORTH],AXIS["Easting",EAST],AUTHORITY["EPSG","8433"]]', '+proj=tmerc +lat_0=22.2123972222222 +lon_0=113.536469444444 +k=1 +x_0=20000 +y_0=20000 +ellps=intl +units=m +no_defs');
-INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (6, 'EPSG', 8857, NULL, '+proj=eqearth +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs');
+INSERT INTO spatial_ref_sys_user(srid, auth_name, auth_srid, srtext, proj4text) VALUES (1, 'EPSG', 4978, 'GEOCCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Geocentric X",OTHER],AXIS["Geocentric Y",OTHER],AXIS["Geocentric Z",NORTH],AUTHORITY["EPSG","4978"]]', '+proj=geocent +datum=WGS84 +units=m +no_defs ');
+INSERT INTO spatial_ref_sys_user(srid, auth_name, auth_srid, srtext, proj4text) VALUES (2, 'EPSG', 4979, 'GEOGCRS["WGS 84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,3],AXIS["geodetic latitude (Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["geodetic longitude (Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],AXIS["ellipsoidal height (h)",up,ORDER[3],LENGTHUNIT["metre",1]],USAGE[SCOPE["unknown"],AREA["World (by country)"],BBOX[-90,-180,90,180]],ID["EPSG",4979]]', '+proj=longlat +datum=WGS84 +no_defs');
+INSERT INTO spatial_ref_sys_user(srid, auth_name, auth_srid, srtext, proj4text) VALUES (3, 'EPSG', 4985, 'BOUNDCRS[SOURCECRS[GEOGCRS["WGS 72",DATUM["World Geodetic System 1972",ELLIPSOID["WGS 72",6378135,298.26,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,3],AXIS["geodetic latitude (Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["geodetic longitude (Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],AXIS["ellipsoidal height (h)",up,ORDER[3],LENGTHUNIT["metre",1]],USAGE[SCOPE["unknown"],AREA["World"],BBOX[-90,-180,90,180]],ID["EPSG",4985]]],TARGETCRS[GEOGCRS["WGS 84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,2],AXIS["latitude",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["longitude",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],ID["EPSG",4326]]],AB
 RIDGEDTRANSFORMATION["WGS 72 to WGS 84 (1)",VERSION["DMA1"],METHOD["Position Vector transformation (geog2D domain)",ID["EPSG",9606]],PARAMETER["X-axis translation",0,ID["EPSG",8605]],PARAMETER["Y-axis translation",0,ID["EPSG",8606]],PARAMETER["Z-axis translation",4.5,ID["EPSG",8607]],PARAMETER["X-axis rotation",0,ID["EPSG",8608]],PARAMETER["Y-axis rotation",0,ID["EPSG",8609]],PARAMETER["Z-axis rotation",0.554,ID["EPSG",8610]],PARAMETER["Scale difference",1.0000002263,ID["EPSG",8611]],USAGE[SCOPE["unknown"],AREA["World"],BBOX[-90,-180,90,180]],ID["DERIVED_FROM(EPSG)",1237]]]', '+proj=longlat +ellps=WGS72 +towgs84=0,0,4.5,0,0,0.554,0.2263 +no_defs');
+INSERT INTO spatial_ref_sys_user(srid, auth_name, auth_srid, srtext, proj4text) VALUES (4, 'EPSG', 8360, 'COMPD_CS["ETRS89 + Baltic 1957 height",GEOGCS["ETRS89",DATUM["European_Terrestrial_Reference_System_1989",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6258"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AXIS["Latitude",NORTH],AXIS["Longitude",EAST],AUTHORITY["EPSG","4258"]],VERT_CS["Baltic 1957 height",VERT_DATUM["Baltic 1957",2005,AUTHORITY["EPSG","1202"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Gravity-related height",UP],AUTHORITY["EPSG","8357"]],AUTHORITY["EPSG","8360"]]', '+proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +vunits=m +no_defs');
+INSERT INTO spatial_ref_sys_user(srid, auth_name, auth_srid, srtext, proj4text) VALUES (5, 'EPSG', 8433, 'PROJCS["Macao 1920 / Macao Grid",GEOGCS["Macao 1920",DATUM["Macao_1920",SPHEROID["International 1924",6378388,297,AUTHORITY["EPSG","7022"]],AUTHORITY["EPSG","1207"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","8428"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",22.2123972222222],PARAMETER["central_meridian",113.536469444444],PARAMETER["scale_factor",1],PARAMETER["false_easting",20000],PARAMETER["false_northing",20000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Northing",NORTH],AXIS["Easting",EAST],AUTHORITY["EPSG","8433"]]', '+proj=tmerc +lat_0=22.2123972222222 +lon_0=113.536469444444 +k=1 +x_0=20000 +y_0=20000 +ellps=intl +units=m +no_defs');
+INSERT INTO spatial_ref_sys_user(srid, auth_name, auth_srid, srtext, proj4text) VALUES (6, 'EPSG', 8857, NULL, '+proj=eqearth +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs');
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (7,'EPSG',2393,'PROJCS["KKJ / Finland Uniform Coordinate System",GEOGCS["KKJ",DATUM["Kartastokoordinaattijarjestelma_1966",SPHEROID["International 1924",6378388,297,AUTHORITY["EPSG","7022"]],TOWGS84[-96.062,-82.428,-121.753,4.801,0.345,-1.376,1.496],AUTHORITY["EPSG","6123"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4123"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",27],PARAMETER["scale_factor",1],PARAMETER["false_easting",3500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","2393"]]','+proj=tmerc +lat_0=0 +lon_0=27 +k=1 +x_0=3500000 +y_0=0 +ellps=intl +towgs84=-96.062,-82.428,-121.753,4.801,0.345,-1.376,1.496 +units=m +no_defs ');
+INSERT INTO "spatial_ref_sys_user" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (7,'EPSG',2393,'PROJCS["KKJ / Finland Uniform Coordinate System",GEOGCS["KKJ",DATUM["Kartastokoordinaattijarjestelma_1966",SPHEROID["International 1924",6378388,297,AUTHORITY["EPSG","7022"]],TOWGS84[-96.062,-82.428,-121.753,4.801,0.345,-1.376,1.496],AUTHORITY["EPSG","6123"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4123"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",27],PARAMETER["scale_factor",1],PARAMETER["false_easting",3500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","2393"]]','+proj=tmerc +lat_0=0 +lon_0=27 +k=1 +x_0=3500000 +y_0=0 +ellps=intl +towgs84=-96.062,-82.428,-121.753,4.801,0.345,-1.376,1.496 +units=m +no_defs ');
 -- Reverse axis with all kind of simples geometry types
@@ -1291,4 +1291,4 @@ SELECT 'double_31', ST_AsEWKT(ST_GeomFromGML('<gml:Point><gml:pos>1 $0%@#$^%#</g
 -- #4652
 SELECT '#4652', ST_AsEWKT(ST_GeomFromGML('<gml:Curve id="id-69b216c9-2c07-434d-8664-e321b3697725-0" srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:28992"> <gml:segments> <gml:LineStringSegment> <gml:posList>119675.91899999976 526436.1209999993 119676.54699999839 526439.4930000007 119676.44299999997 526439.5130000003 119676.03299999982 526439.6220000014 119675.38500000164 526439.868999999</gml:posList> </gml:LineStringSegment> <gml:LineStringSegment> <gml:posList>119675.38500000164 526439.868999999 119675.15500452081 526439.9735735222 119674.92922525379 526440.0869634049 119674.70800000057 526440.2089999989</gml:posList> </gml:LineStringSegment> <gml:LineStringSegment> <gml:posList>119674.70800000057 526440.2089999989 119674.01347910661 526440.6575801083 119673.38748824484 526441.1976901226</gml:posList> </gml:LineStringSegment> </gml:segments> </gml:Curve>',28992));
-DELETE FROM spatial_ref_sys WHERE srid BETWEEN 1 and 7;
+DELETE FROM spatial_ref_sys_user WHERE srid BETWEEN 1 and 7;
diff --git a/regress/core/regress_proj_adhoc.sql b/regress/core/regress_proj_adhoc.sql
index 5d2814cdd..5d665494e 100644
--- a/regress/core/regress_proj_adhoc.sql
+++ b/regress/core/regress_proj_adhoc.sql
@@ -1,10 +1,10 @@
 -- some transform() regression
--- prime spatial_ref_sys table with two projections
+-- prime spatial_ref_sys_user table with two projections
 --- EPSG 100001 : WGS 84 / UTM zone 33N
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (100001,'EPSG',100001,'PROJCS["WGS 84 / UTM zone 33N",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","1000002"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",15],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","100001"]]','+proj=utm +zone=33 +ellps=WGS84 +datum=WGS84 +units=m +no_defs ');
+INSERT INTO "spatial_ref_sys_user" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (100001,'EPSG',100001,'PROJCS["WGS 84 / UTM zone 33N",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","1000002"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",15],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","100001"]]','+proj=utm +zone=33 +ellps=WGS84 +datum=WGS84 +units=m +no_defs ');
 --- EPSG 100002 : WGS 84
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (100002,'EPSG',100002,'GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","100002"]]','+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs ');
+INSERT INTO "spatial_ref_sys_user" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (100002,'EPSG',100002,'GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","100002"]]','+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs ');
 -- Repeat all tests with the new function names.
 --- test #0: NULL values
@@ -39,4 +39,4 @@ SELECT 12, ST_AsEWKT(ST_Transform(
            ST_GeomFromEWKT('SRID=100002;POINT(16 48)'),
            'invalid projection'));
-DELETE FROM spatial_ref_sys WHERE srid in (100001, 100002);
+DELETE FROM spatial_ref_sys_user WHERE srid in (100001, 100002);
diff --git a/regress/core/regress_proj_basic.sql b/regress/core/regress_proj_basic.sql
index ca406e155..700d6558d 100644
--- a/regress/core/regress_proj_basic.sql
+++ b/regress/core/regress_proj_basic.sql
@@ -1,10 +1,10 @@
 --- test #1: a simple projection
 SELECT 1,ST_AsEWKT(ST_SnapToGrid(ST_transform(ST_GeomFromEWKT('SRID=100002;POINT(16 48)'),100001),10));
@@ -21,7 +21,7 @@ SELECT 4,ST_AsEWKT(ST_SnapToGrid(ST_transform(ST_GeomFromEWKT('SRID=100002;LINES
 --- test #5: LINESTRING projection, 2 points, 4D
 SELECT 5,ST_AsEWKT(ST_SnapToGrid(ST_transform(ST_GeomFromEWKT('SRID=100002;LINESTRING(16 48 0 0, 16 49 0 0)'),100001),10));
 SELECT 'M1', ST_AsText(ST_SnapToGrid(st_transform('SRID=4326;POINT(-20 -20)'::geometry, 3857),1));
 SELECT 'M2', ST_AsText(ST_SnapToGrid(st_transform('SRID=4326;POINT(-20 -21.5)'::geometry, 3857),1));
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 3c575bb8d..979821c0f 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -549,10 +549,10 @@ with inp AS ( SELECT
 FROM inp;
 -- #1150
-insert into spatial_ref_sys (srid, proj4text) values (500001,NULL);
-insert into spatial_ref_sys (srid, proj4text) values (500002, '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs');
+insert into spatial_ref_sys_user (srid, proj4text) values (500001,NULL);
+insert into spatial_ref_sys_user (srid, proj4text) values (500002, '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs');
 select '#1150', st_astext(st_transform('SRID=500002;POINT(0 0)'::geometry,500001));
-delete from spatial_ref_sys where srid in (500001,500002);
+delete from spatial_ref_sys_user where srid in (500001,500002);
 -- #1038
 select '#1038', ST_AsSVG('POLYGON EMPTY'::geometry);
Summary of changes:
 raster/test/regress/rt_asraster.sql | 24 ++++++++++++------------
 raster/test/regress/rt_gdalwarp.sql | 28 ++++++++++++----------------
 regress/core/in_gml.sql             | 16 ++++++++--------
 regress/core/regress_proj_adhoc.sql |  8 ++++----
 regress/core/regress_proj_basic.sql |  8 ++++----
 regress/core/tickets.sql            |  6 +++---
 6 files changed, 43 insertions(+), 47 deletions(-)
hooks/post-receive
