[postgis-tickets] [PostGIS] #5080: script based upgrade from 2.5.6 fails: ERROR: window function st_clusterkmeans requires an OVER clause
trac at osgeo.org
Thu Feb 3 05:43:32 PST 2022
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.3.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by strk):
It's incredible that extension upgrade works fine. There must be something
wrong I did with handling Replaces which only works in extension and not
in script based.
I plan to add script-based upgrade testing in Dronie (started with
[64abce15057e9606f3d8399ea22dc31a865a52e6/git] and continuing in
https://git.osgeo.org/gitea/postgis/postgis/pulls/88
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5080#comment:2>
