[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-473-g2fca37fcd
    git at osgeo.org
    git at osgeo.org
    Thu Feb  3 10:42:14 PST 2022
the project "PostGIS".
       via  2fca37fcdd2effe84595ec313fb0e378e7f48c4c (commit)
       via  00085d0bcad221f4b8e6c0698ed3eca17e87960b (commit)
      from  58a27e141d9d681ecb955860a179d32a1a274a38 (commit)
revisions in full, below.
commit 2fca37fcdd2effe84595ec313fb0e378e7f48c4c
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Feb 3 19:41:56 2022 +0100
    [dronie] Print also INFO from check_all_upgrades
diff --git a/ci/dronie/postgis_regress.sh b/ci/dronie/postgis_regress.sh
index f74054b94..cde58b38d 100644
--- a/ci/dronie/postgis_regress.sh
+++ b/ci/dronie/postgis_regress.sh
@@ -50,4 +50,4 @@ tee check.log < check.fifo &
 ${SRCDIR}/utils/check_all_upgrades.sh -s ${CURRENTVERSION}! > check.fifo
 wait # for tee process to flush its buffers
 echo "-- Summary of upgrade tests --"
-egrep '(PASS|FAIL|SKIP)' check.log
+egrep '(PASS|FAIL|SKIP|INFO)' check.log
commit 00085d0bcad221f4b8e6c0698ed3eca17e87960b
Date:   Thu Feb 3 17:18:12 2022 +0100
    check_all_upgrade improvements
    Generalize labeling of SKIP messages
    Generalize postgresql/postgis support matrix
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 905c7ceb8..20e96f8ee 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -1,6 +1,14 @@
 #!/bin/sh
 EXIT_ON_FIRST_FAILURE=0
+BUILDDIR=$PWD
+EXTDIR=`pg_config --sharedir`/extension/
+CTBDIR=`pg_config --sharedir`/contrib/
+TMPDIR=/tmp/check_all_upgrades-$$-tmp
+PGVER=`pg_config --version | awk '{print $2}'`
+PGVER_MAJOR=$(echo "${PGVER}" | sed 's/\.[^\.]*//')
+echo "INFO: PostgreSQL version: ${PGVER} [${PGVER_MAJOR}]"
 if test "$1" = "-s"; then
   EXIT_ON_FIRST_FAILURE=1
@@ -14,14 +22,13 @@ if test -z "$1"; then
   exit 1
 fi
-to_version_param="$1"
-to_version=$to_version_param
-if expr $to_version : ':auto' >/dev/null; then
-  export PGDATABASE=template1
-  to_version=`psql -XAtc "select default_version from pg_available_extensions where name = 'postgis'"` || exit 1
-elif expr $to_version : '.*!$' >/dev/null; then
-  to_version=$(echo "${to_version}" | sed 's/\!$//')
-fi
+mkdir -p ${TMPDIR}
+cleanup()
+  rm -rf ${TMPDIR}
+trap 'cleanup' 0
 # Return -1, 1 or 0 if the first version
@@ -53,27 +60,6 @@ semver_compare()
   echo 0; return;
-BUILDDIR=$PWD
-EXTDIR=`pg_config --sharedir`/extension/
-CTBDIR=`pg_config --sharedir`/contrib/
-PGVER=`pg_config --version | awk '{print $2}'`
-echo "PostgreSQL version: ${PGVER}"
-cd $EXTDIR
-failures=0
-INSTALLED_EXTENSIONS=postgis
-if test -f postgis_topology--${to_version}.sql; then
-  INSTALLED_EXTENSIONS="$INSTALLED_EXTENSIONS postgis_topology"
-fi
-if test -f postgis_raster--${to_version}.sql; then
-  INSTALLED_EXTENSIONS="$INSTALLED_EXTENSIONS postgis_raster"
-fi
-echo "INFO: installed extensions: $INSTALLED_EXTENSIONS"
 failed()
   failures=$((failures+1))
@@ -82,9 +68,35 @@ failed()
   fi
+minimum_postgis_version_for_postgresql_major_version()
+  pgver=$1
+  supportfile=${TMPDIR}/minimum_supported_version_for_postgresql
+  if ! test -e ${supportfile}; then
+    # Source: https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
+    cat > ${supportfile} <<EOF
+9.6:2.3
+10:2.4
+11:2.5
+12:2.5
+13:3.0
+14:3.1
+EOF
+  fi
+  # Drop patch-level number from PostgreSQL version
+  minsupported=`grep ^${pgver}: ${supportfile} | cut -d: -f2`
+  test -n "${minsupported}" || {
+    echo "Cannot detemine minimum supported PostGIS version for PostgreSQL major version ${pgver}" >&2
+    exit 1
+  echo "${minsupported}"
 compatible_upgrade()
-  upgrade_path=$1
+  label=$1
   from=$2
   to=$3
@@ -92,24 +104,49 @@ compatible_upgrade()
   #echo "XXXX compatible_upgrade: from=${from}"
   #echo "XXXX compatible_upgrade: to=${to}"
-  # only consider versions older than ${to_version_param}
+  # only consider versions older than ${to}
   cmp=`semver_compare "${from}" "${to}"`
+  #echo "INFO: semver_compare ${from} ${to} returned $cmp"
   if test $cmp -ge 0; then
-    echo "SKIP: upgrade $upgrade_path ($to is not newer than $from)"
+    echo "SKIP: $label ($to is not newer than $from)"
     return 1
   fi
-  cmp=`semver_compare "${PGVER}" "11"`
-  if test $cmp -ge 0; then
-    cmp=`semver_compare "3.0" "${from}"`
-      echo "SKIP: upgrade $UPGRADE_PATH ($from < 3.0 which is required to run in PostgreSQL ${PGVER})"
-      return 1
-    fi
+  cmp=`semver_compare "${PGIS_MIN_VERSION}" "${from}"`
+  if test $cmp -gt 0; then
+    echo "SKIP: $label ($from older than ${PGIS_MIN_VERSION}, which is required to run in PostgreSQL ${PGVER})"
+    return 1
   fi
   return 0
+to_version_param="$1"
+to_version=$to_version_param
+if expr $to_version : ':auto' >/dev/null; then
+  export PGDATABASE=template1
+  to_version=`psql -XAtc "select default_version from pg_available_extensions where name = 'postgis'"` || exit 1
+elif expr $to_version : '.*!$' >/dev/null; then
+  to_version=$(echo "${to_version}" | sed 's/\!$//')
+fi
+PGIS_MIN_VERSION=`minimum_postgis_version_for_postgresql_major_version "${PGVER_MAJOR}"`
+echo "INFO: minimum PostGIS version supporting PostgreSQL ${PGVER_MAJOR}: ${PGIS_MIN_VERSION}"
+cd $EXTDIR
+failures=0
+INSTALLED_EXTENSIONS=postgis
+if test -f postgis_topology--${to_version}.sql; then
+  INSTALLED_EXTENSIONS="$INSTALLED_EXTENSIONS postgis_topology"
+fi
+if test -f postgis_raster--${to_version}.sql; then
+  INSTALLED_EXTENSIONS="$INSTALLED_EXTENSIONS postgis_raster"
+fi
+echo "INFO: installed extensions: $INSTALLED_EXTENSIONS"
 for EXT in ${INSTALLED_EXTENSIONS}; do
   if test "${EXT}" = "postgis"; then
     REGDIR=${BUILDDIR}/regress
@@ -128,45 +165,45 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
   for fname in $files; do
     from_version="$fname"
     UPGRADE_PATH="${from_version}--${to_version_param}"
+    test_label="${EXT} extension upgrade ${UPGRADE_PATH}"
+    if expr $to_version_param : ':auto' >/dev/null; then
+      test_label="${test_label} ($to_version)"
+    fi
+    compatible_upgrade "${test_label}" ${from_version} ${to_version} || continue
     UPGRADE_FILE="${EXT}--${from_version}--${to_version}.sql"
-    compatible_upgrade ${UPGRADE_PATH} ${from_version} ${to_version} || continue
-    if test -e ${UPGRADE_FILE}; then
-      if expr $to_version_param : ':auto' >/dev/null; then
-        echo "Testing ${EXT} upgrade $UPGRADE_PATH ($to_version)"
-      else
-        echo "Testing ${EXT} upgrade $UPGRADE_PATH"
-      fi
-      RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
-      make -C ${REGDIR} check && {
-        echo "PASS: ${EXT} upgrade $UPGRADE_PATH"
-        echo "FAIL: ${EXT} upgrade $UPGRADE_PATH"
-        failed
-    else
-      echo "SKIP: ${EXT} upgrade $UPGRADE_FILE is missing"
+    if ! test -e ${UPGRADE_FILE}; then
+      echo "SKIP: ${test_label} ($UPGRADE_FILE is missing)"
+      continue
     fi
+    echo "Testing ${test_label}"
+    RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
+    make -C ${REGDIR} check && {
+      echo "PASS: ${test_label}"
+      echo "FAIL: ${test_label}"
+      failed
   done
   # Check unpackaged->extension upgrades
   for majmin in `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`; do
     UPGRADE_PATH="unpackaged${majmin}--${to_version_param}"
+    fi
+    compatible_upgrade "${test_label}" ${majmin} ${to_version} || continue
     UPGRADE_FILE="${EXT}--unpackaged--${to_version}.sql"
       continue
     fi
-    compatible_upgrade ${UPGRADE_PATH} ${majmin} ${to_version} || continue
-    else
-    fi
       failed
   done
Summary of changes:
 ci/dronie/postgis_regress.sh |   2 +-
 utils/check_all_upgrades.sh  | 165 ++++++++++++++++++++++++++-----------------
 2 files changed, 102 insertions(+), 65 deletions(-)
hooks/post-receive
