[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-485-g0e97ae29e
Fri Feb 4 15:08:05 PST 2022
the project "PostGIS".
       via  0e97ae29ee2f3f3abcd127a912e4baa739731ff0 (commit)
      from  124c8c7cd13587a8f84c64a99031c335971cc0dd (commit)
revisions in full, below.
commit 0e97ae29ee2f3f3abcd127a912e4baa739731ff0
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Feb 5 00:06:38 2022 +0100
    Reword messages from postgis_extensions_upgrade() to be less scary
    There's no need to say that extension are "not packageable"
    because that's not true, they are just not in use...
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 0f86459c4..d3450bbf2 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2959,6 +2959,7 @@ DECLARE
 	rec record;
 	sql text;
 	var_schema text;
+	target_version text; -- TODO: optionally take as argument
 BEGIN
 	FOR rec IN
@@ -2973,10 +2974,15 @@ BEGIN
 		ORDER BY length(name) -- this is to make sure 'postgis' is first !
 	LOOP --{
-		IF rec.installed_version IS NULL THEN
+		IF target_version IS NULL THEN
+			target_version := rec.default_version;
+		END IF;
+		IF rec.installed_version IS NULL THEN --{
 			-- If the support installed by available extension
 			-- is found unpackaged, we package it
-			IF
+			IF --{
 				 -- PostGIS is always available (this function is part of it)
 				 rec.name = 'postgis'
@@ -3003,7 +3009,7 @@ BEGIN
 							SELECT 1 FROM pg_catalog.pg_class c
 							JOIN pg_catalog.pg_namespace n ON (c.relnamespace = n.oid )
 							WHERE n.nspname = 'tiger' AND c.relname = 'geocode_settings') )
-			THEN
+			THEN --}{
 				-- Force install in same schema as postgis
 				SELECT INTO var_schema n.nspname
 				  FROM pg_namespace n, pg_proc p
@@ -3015,46 +3021,50 @@ BEGIN
 					sql := format(
 							  'CREATE EXTENSION %1$I SCHEMA %2$I VERSION unpackaged;'
 							  'ALTER EXTENSION %1$I UPDATE TO %3$I',
-							  rec.name, var_schema, rec.default_version);
+							  rec.name, var_schema, target_version);
 				ELSE
 					sql := format(
 							 'CREATE EXTENSION %1$I VERSION unpackaged;'
 							 'ALTER EXTENSION %1$I UPDATE TO %2$I',
-							 rec.name, rec.default_version);
+							 rec.name, target_version);
 				END IF;
-				RAISE NOTICE 'Packaging extension %', rec.name;
+				RAISE NOTICE 'Packaging and updating %', rec.name;
 				RAISE DEBUG '%', sql;
 				EXECUTE sql;
 			ELSE
-				RAISE NOTICE 'Extension % is not available or not packagable for some reason', rec.name;
+				RAISE DEBUG 'Skipping % (not in use)', rec.name;
 			END IF;
-		ELSIF rec.default_version != rec.installed_version
-		THEN
+		ELSIF target_version != rec.installed_version
+		THEN --}{
 			sql = 'ALTER EXTENSION ' || rec.name || ' UPDATE TO ' ||
-						quote_ident(rec.default_version)   || ';';
-			RAISE NOTICE 'Updating extension % from % to %',
-				rec.name, rec.installed_version, rec.default_version;
+						quote_ident(target_version)   || ';';
+			RAISE NOTICE 'Updating extension % %',
+				rec.name, rec.installed_version;
 			EXECUTE sql;
-		ELSIF (rec.default_version = rec.installed_version AND rec.installed_version ILIKE '%dev') OR
+		ELSIF (target_version = rec.installed_version AND rec.installed_version ILIKE '%dev') OR
 			(@extschema at ._postgis_pgsql_version() != @extschema at ._postgis_scripts_pgsql_version())
-		THEN
+		THEN --}{
 			-- we need to upgrade to next and back
-			RAISE NOTICE 'Updating extension % %',
+			RAISE NOTICE 'Updating extension % % (self refresh)',
-						quote_ident(rec.default_version || 'next')   || ';';
+						quote_ident(target_version || 'next')   || ';';
 			EXECUTE sql;
 			EXECUTE sql;
-		END IF;
+		END IF; --}
 	END LOOP; --}
-	RETURN 'Upgrade completed, run SELECT postgis_full_version(); for details';
+	RETURN format(
+		'Upgrade to version %s completed, run SELECT postgis_full_version(); for details',
+		target_version
 END
 $$ LANGUAGE plpgsql VOLATILE;
Summary of changes:
 postgis/postgis.sql.in | 48 +++++++++++++++++++++++++++++-------------------
 1 file changed, 29 insertions(+), 19 deletions(-)
hooks/post-receive
