[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-505-g981fb9390
Mon Feb 7 11:13:32 PST 2022
the project "PostGIS".
       via  981fb9390891328a9d82f2731ef81101826a73b5 (commit)
      from  05d3150c9222bd781871e627cf5b3973d18bcfc2 (commit)
revisions in full, below.
commit 981fb9390891328a9d82f2731ef81101826a73b5
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Feb 7 11:13:27 2022 -0800
    Remove doc image generator unused code
diff --git a/doc/html/image_src/generator.c b/doc/html/image_src/generator.c
index 9679809d8..97b325667 100644
--- a/doc/html/image_src/generator.c
+++ b/doc/html/image_src/generator.c
@@ -269,43 +269,6 @@ drawGeometry(char *output, LWGEOM *lwgeom, LAYERSTYLE *styles )
 	return (ptr - output);
- * Invokes a system call to ImageMagick's "convert" command that adds a drop
- * shadow to the current layer image.
- * @param layerNumber the current working layer number.
-static void
-addDropShadow(int layerNumber)
-	char str[512];
-	sprintf(
-	    str,
-	    "convert tmp%d.png -gravity center \"(\" +clone -background navy -shadow 100x3+4+4 \")\" +swap -background none -flatten tmp%d.png",
-	    layerNumber, layerNumber);
-	LWDEBUGF(4, "%s", str);
-	checked_system(str);
- * highlight to the current layer image.
-static void
-addHighlight(int layerNumber)
-	// TODO: change to properly sized string
-	char str[512];
-	sprintf(
-	    str,
-	    "convert tmp%d.png \"(\" +clone -channel A -separate +channel -negate -background black -virtual-pixel background -blur 0x3 -shade 120x55 -contrast-stretch 0%% +sigmoidal-contrast 7x50%% -fill grey50 -colorize 10%% +clone +swap -compose overlay -composite \")\" -compose In -composite tmp%d.png",
  * Invokes a system call to ImageMagick's "convert" command that reduces
  * the overall filesize
@@ -485,9 +448,6 @@ int main( int argc, const char* argv[] )
 		checked_system(output);
-		//-- (MD) disable highlighting since it doesn't work well with opacity
-		//addHighlight( layerCount );
-		// addDropShadow( layerCount );
 		layerCount++;
 		free(styleName);
Summary of changes:
 doc/html/image_src/generator.c | 40 ----------------------------------------
 1 file changed, 40 deletions(-)
hooks/post-receive
