[postgis-tickets] [PostGIS] #5078: 2.5.6dev--3.3.0dev upgrade fails: cannot change name of input parameter "param_geom"
PostGIS trac at osgeo.org
Tue Feb 8 12:02:10 PST 2022
"param_geom"
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by pramsey):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 Your fix is fine, I'm re-closing this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5078#comment:10>
