[postgis-tickets] [PostGIS] #5024: spatial_ref_sys table not updated with new entries
    trac at osgeo.org
    Wed Feb  9 01:40:06 PST 2022
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  reopened
  Priority:  medium   |  Milestone:  PostGIS 3.3.0
 Component:  postgis  |    Version:  3.1.x
Resolution:           |   Keywords:
Comment (by strk):
 What I'm not sure about is whether we can REALLY clearly document and
 stick to SRID ranges, which is what you're basically saying with:
 > out of the way of EPSG (<32600) and out of the way of ESRI
 This is my current set of max srids per auth_name:
 strk=# select max(srid), auth_name from spatial_ref_sys group by
 auth_name;
   max   |       auth_name
  900913 | spatialreferencing.org
   32766 | EPSG
  104992 | ESRI
 (3 rows)
 In my 2012 mail I tried to discuss this but nobody followed up:
 https://lists.osgeo.org/pipermail/postgis-devel/2012-February/018440.html
 Sticking with a fixed system range means simplifying the pg_extension
 record as to what needs to be dumped from spatial_ref_sys. It still
 doesn't save "tweaks to system SRIDs" but so far I think nobody came up
 with that use case.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5024#comment:27>
