[postgis-tickets] [PostGIS] #5089: ST_Reverse does not handle CURVEPOLYGON/COMPOUNDCURVE correctly
PostGIS trac at osgeo.org
Wed Feb 9 03:23:43 PST 2022
 Reporter:  bhoefling  |      Owner:  strk
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 3.3.0
Component:  liblwgeom  |    Version:  3.2.x
 Keywords:             |
 ST_Reverse works for CIRCULARSTRING, and for simple  CURVEPOLYGON.
 But if the CURVEPOLYGON contains a COMPOUNDCURVE with more than one
 component, the reverse order is wrong.
 Testcase is from here:
 https://github.com/postgis/postgis/blob/f6def67654c25d812446239036cee44812613748/regress/core/reverse.sql#L47
 Actual Result:
 SELECT 'cplg2', ST_AsText(ST_Reverse('CURVEPOLYGON (COMPOUNDCURVE
 (CIRCULARSTRING (0 0,1 1,1 0),(1 0,0 1),(0 1,0 0)))'::geometry));
  ?column? |                                  st_astext
  cplg2    | CURVEPOLYGON(COMPOUNDCURVE(CIRCULARSTRING(1 0,1 1,0 0),(0 1,1
 0),(0 0,0 1)))
 (1 row)
 Note that each sub-component is reversed. But it is necessary to
 additionally reverse the order of the components as such. Otherwise, the
 end/start nodes don't match any more.
 EXPECTED:
 CURVEPOLYGON(COMPOUNDCURVE((0 0,0 1), (0 1,1 0), CIRCULARSTRING(1 0,1 1,0
 0)))
 Implementation details:
 lwgeom.c, lwgeom_reverse_in_place(LWGEOM *geom)
 https://github.com/postgis/postgis/blob/2fb15205263248249b1f1dd09abc117e8f67807c/liblwgeom/lwgeom.c#L135
 This CASE needs to be differentiated more.
 Tested on Docker postgis/postgis:13-master
 SELECT postgis_full_version();
 --  POSTGIS="3.3.0dev 3.2.0-398-g4fa57df0b" [EXTENSION] PGSQL="130"
 GEOS="3.11.0dev-CAPI-1.16.0" PROJ="8.2.0" LIBXML="2.9.10" LIBJSON="0.15"
 LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" (core procs from "3.1.4
 ded6c34" need upgrade)
 SELECT version();
                                                            version
  PostgreSQL 13.5 (Debian 13.5-1.pgdg110+1) on x86_64-pc-linux-gnu,
 compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
 Björn
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5089>
