[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.0-32-g5fae8e542
git at osgeo.org
git at osgeo.org
Sat Feb 12 16:20:34 PST 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
via 5fae8e542ac40ffb2f01c8bcecb1f95d64c1b3a7 (commit)
via ecad675f3c102771ea930ce9bad5ca91d220d076 (commit)
from b0458b851d9d022941a76ee19ce4752a307970fa (commit)
revisions in full, below.
commit 5fae8e542ac40ffb2f01c8bcecb1f95d64c1b3a7
Author: Regina Obe <lr at pcorp.us>
Date: Sat Feb 12 19:20:28 2022 -0500
Update News, docs, and general prep for 3.2.1 release
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 16c57974c..5f3a0fbed 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -1,6 +1,6 @@
How to release
-Date: 2020-02-23
+Date: 2020-02-13
Versioning Scheme
diff --git a/NEWS b/NEWS
index 81b0045d2..e4df8b33a 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
-PostGIS 3.2.1dev
-2022/02/DD
+PostGIS 3.2.1
+2022/02/12
* Bug Fixes *
- #5033, #5035, allow upgrades in presence of views using deprecated
@@ -12,6 +12,9 @@ PostGIS 3.2.1dev
- #5076, stop install when pgaudit is active (Paul Ramsey)
- #5069, search_path vulnerabilty during install/upgrade
(Regina Obe)
+ - #5090, #5091 configure --with-protobuf-lib / --with-protobufdir
+ , --without-protobuf broken (Tobias Bussmann)
PostGIS 3.2.0 (Olivier Courtin Edition)
diff --git a/README.postgis b/README.postgis
index 0b84fb92d..a7483d9fd 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.2.0
-:Date: 2021-12-17
+:Version: 3.2.1
+:Date: 2022-02-12
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index a2d89275b..849bfe701 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=1dev
+POSTGIS_MICRO_VERSION=1
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 0262cc04e..e6cb6b2ef 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -4,7 +4,7 @@
<subtitle>Release Notes</subtitle>
<sect1>
<title>PostGIS 3.2.1</title>
- <para>2022/02/13</para>
+ <para>2022/02/12</para>
<para>This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
Additional features are enabled if you are running GEOS 3.9+
(and ST_MakeValid enhancements with 3.10+),
@@ -21,6 +21,8 @@
<para>5076, stop install when pgaudit is active (Paul Ramsey)</para>
<para>5069, search_path vulnerabilty during install/upgrade
(Regina Obe)</para>
+ <para>5090, 5091 configure --with-protobuf-lib /
+ --with-protobufdir, --without-protobuf broken (Tobias Bussmann)</para>
</simplesect>
</sect1>
commit ecad675f3c102771ea930ce9bad5ca91d220d076
Date: Sat Feb 12 19:10:02 2022 -0500
Closes #5090 for PostGIS 3.2.1
Closes #5091 for PostGIS 3.2.1
Fix --with-protobuf-lib / --with-protobufdir broken
References https://github.com/postgis/postgis/pull/662
References https://github.com/postgis/postgis/pull/663
diff --git a/configure.ac b/configure.ac
index f41bbfb2a..f07ee41d5 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1013,7 +1013,7 @@ if test "$CHECK_PROTOBUF" != "no"; then
if test "x$withval" = "xyes"; then
AC_MSG_ERROR([you must specify a parameter to --with-protobufdir, e.g. --with-protobufdir=/usr/local])
else
- PROTOBUF_LDFLAGS="-L$withval/lib";
+ PROTOBUF_LDFLAGS="-L$withval/lib -lprotobuf-c";
PROTOBUF_CPPFLAGS="-I$withval/include"
fi
@@ -1025,7 +1025,7 @@ if test "$CHECK_PROTOBUF" != "no"; then
AC_ARG_WITH([protobuf-lib],
[AS_HELP_STRING([--with-protobuf-lib=PATH], [libprotobuf-c.so/dll/dylib library installation directory])], [
- PROTOBUF_LDFLAGS="-L$withval"
+ PROTOBUF_LDFLAGS="-L$withval -lprotobuf-c"
if test -n "$PROTOBUF_CPPFLAGS"; then
@@ -1043,8 +1043,11 @@ if test "$CHECK_PROTOBUF" != "no"; then
dnl confirm that discovered/configured library path works
- AC_CHECK_LIB([protobuf-c], [protobuf_c_message_init],
+ AC_CHECK_LIB([protobuf-c], [protobuf_c_message_init],[
+ if test "x$PROTOBUF_LDFLAGS" = "x"; then
+ PROTOBUF_LDFLAGS="-lprotobuf-c"
+ fi
AC_MSG_ERROR([unable to link protobuf-c using $LDFLAGS. You can disable MVT and Geobuf support using --without-protobuf])
HAVE_PROTOBUF=no
Summary of changes:
HOWTO_RELEASE | 2 +-
NEWS | 7 +++++--
README.postgis | 4 ++--
Version.config | 2 +-
configure.ac | 11 +++++++----
doc/release_notes.xml | 4 +++-
6 files changed, 19 insertions(+), 11 deletions(-)
hooks/post-receive
