[postgis-tickets] [PostGIS] #5091: configure --without-protobuf broken
trac at osgeo.org
Sat Feb 12 16:20:37 PST 2022
Reporter: tbussmann | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.2.1
Component: build/upgrade/install | Version: 3.2.x
Resolution: fixed | Keywords:
Changes (by Regina Obe <lr@…>):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"ecad675f3c102771ea930ce9bad5ca91d220d076/git" ecad675/git]:
#!CommitTicketReference repository="git"
revision="ecad675f3c102771ea930ce9bad5ca91d220d076"
Closes #5090 for PostGIS 3.2.1
Closes #5091 for PostGIS 3.2.1
Fix --with-protobuf-lib / --with-protobufdir broken
References https://github.com/postgis/postgis/pull/662
References https://github.com/postgis/postgis/pull/663
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5091#comment:1>
